Torque Converter Installation
Old Apr 10, 2009 | 10:02 AM
whitetrash's Avatar
whitetrash
I finally have the truck painted the engine rebuilt and I am getting ready to put the 390 and C6 back in the truck. I am intending to mate the engine and transmission, and then install as one unit unless I you all think that is a bad idea. While rebuilding the engine I used a book by Steve Christ “How to Rebuild Big Block Ford Engines” (after I had already torn down the engine). The book says I should have marked a stud on the torque converter in relation to the flywheel; I didn’t do that of course. So is there a procedure to reinstalling the torque converter? Is it a balance thing? Am I just screwed? Any help would be great.
<O</O
Thanks,
Chad
Old Apr 10, 2009 | 10:14 AM
whitetrash's Avatar
whitetrash
I guess Torque Converter and Flywheel in the same sentence sounds pretty dumb. I meant Flexplate.
Chad
Old Apr 10, 2009 | 11:50 AM
Bear 45/70's Avatar
Bear 45/70
There is a drain plug on the converter that needs to lineup with a corresponding hole in the flex plate (it's is not a flywheel). That's why you need to mark the converter bolt.
Old Apr 15, 2009 | 05:28 AM
tomw's Avatar
tomw
The nuts do not need a lot of torque, and you should make sure that they are the original or equivalent as I think they are self-locking with a plastic bit embedded internally in the threads. When I last did this stuff, I would make sure the orientation of the TC and flex plate were on a common clock point, such as the 6pm position, as it is not much fun to try to manipulate the TC forward and line up the stud/hole at the same time. A lot easier to put it in already clocked.
tom
Flintknapper
17
Feb 18, 2015 08:00 PM
Lance Hogan
38
May 11, 2008 12:01 AM
Jodell
Dec 22, 2007 06:03 AM
Lance Hogan
Sep 8, 2007 03:31 PM
92Bronco-SA-TX
48
Aug 9, 2005 02:55 PM
