Silly wifes...
Old Apr 9, 2009 | 12:54 PM
superduty4x4's Avatar
superduty4x4
Wink Silly wifes...
My wife rode in my truck last night for the first time since I installed the AIC. She asked if I was going to add any more stuff inside the cab after that, because "its starting to look like an airplane cockpit in here instead of a truck."
I need to show her pics of CSIPSD's interior
Old Apr 9, 2009 | 01:00 PM
Izzy351's Avatar
Izzy351
What's an "AIC"?
Old Apr 9, 2009 | 01:02 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Originally Posted by Izzy351
What's an "AIC"?
AIC= Auxiliary Idle Control.
Old Apr 9, 2009 | 01:07 PM
Izzy351's Avatar
Izzy351
So, some kind of variable idle ****?? I was going to do that, but when I switched to Tony's tunes, it was an easy decision to add High-Idle since I had all the performance reburns I wanted and still had a slot left...
Old Apr 9, 2009 | 01:10 PM
CSIPSD's Avatar
CSIPSD
Old Apr 9, 2009 | 01:13 PM
CSIPSD's Avatar
CSIPSD
No, its a factory Ford Item used alot in tow trucks and other commercial apps. It has a digital read out that you can ajusts, gives the RPM's and such... Very slick little unit.
Old Apr 9, 2009 | 01:27 PM
superduty4x4
Not exactly... link coming in a bit.
Old Apr 9, 2009 | 01:31 PM
Sparky83's Avatar
Sparky83
ok... i want listing of what all those gauges are...
Old Apr 9, 2009 | 01:32 PM
superduty4x4
AIC Install- early 99. That thread has all the info on the AIC Joe.
AIC Operation Manual for more info.
Old Apr 9, 2009 | 01:48 PM
krejci.mike's Avatar
krejci.mike
I saw that you traded for yours but do you know where you can buy one?
Old Apr 9, 2009 | 01:50 PM
superduty4x4
Ebay, Craigslist, junk yard are the best bets.
Old Apr 9, 2009 | 02:45 PM
RFD_Truckie's Avatar
RFD_Truckie
Me Too....
Old Apr 9, 2009 | 02:49 PM
03_PSD's Avatar
03_PSD
My wife thinks I'm strange cause I keep such a close eye on the gauges.
Old Apr 9, 2009 | 02:58 PM
bdrummonds's Avatar
bdrummonds
Originally Posted by RFD_Truckie
Me Too....
the list of whats installed and currently reading is not nearly as impressive as the tacklebox behind the seat with the other 20 or so guages he can plug in at will.
Old Apr 9, 2009 | 03:32 PM
CSIPSD's Avatar
CSIPSD
Me Too....
A-pillar, Top to bottom...
Manifold Pressure 0-60
Boost Pressure 0-60
Right Pyro
Left Pyro
Overhead pod Left to Right
Tranny Temp 0-280
Diff Temp 0-280
Oil Temp 0-280
Water Temp 0-280
Under Dash Left to Right
Fuel Pressure 0-100
Oil Pressure 0-100
Air Pressure 0-180
Dash Suround
Drive oil Pressure 0-400
Post IC air temp 0-280
Volts
Fuel level (big tank in bed)
and then a scan gauge on the steering column, and a water pressure for the water injection on the dash...
