Flashing overdrive light
Old Apr 9, 2009 | 10:45 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by megawatt00
Is it flashing in a sequence? If so count them and let us know.
The OD light does not flash any sequences. It flashes at a steady 1 hz.
Old Apr 10, 2009 | 01:19 AM
pmbmax's Avatar
pmbmax
I would pull the rearend sensor and clean it with a clean towel see if any thing is stuck on it. tack a 12 mm and 5 min. On top of rear worth a try.
Old Apr 10, 2009 | 06:17 AM
megawatt00's Avatar
megawatt00
I was thinking of something else. Thanks for the correction.
Old Apr 10, 2009 | 08:01 AM
mblanken881's Avatar
mblanken881
It's probably the sensor because I drive through dirt and mud all day on the jobsite.
Old Apr 10, 2009 | 08:39 AM
Supercab's Avatar
Supercab
Wink
Someone said in a previous post about this that it was usually the VSS sensor located on the rear end and that the NAPA replacement is actually better than the factory Ford unit.
