Turbo rebuild
Old Apr 9, 2009 | 11:39 AM
jt371's Avatar
jt371
______
Turbo rebuild
Have a bolt missing on the exhaust side of the turbo housing, ehaust leaking by a little as well. The up-pipes leak a little as well. My question is Where to buy the turbo rebuild kit and up-pipe gaskets for the stock pipes? I can't afford to install bellowed up-pipes. Also should I look into a wicked wheel? Truck is stock now just a 6637 and CCV done. I plan to do a DP tuner someday.
Old Apr 9, 2009 | 11:41 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Just because a bolt backed out doesn't mean you need to rebuild it. Did you check your shaft play? Or do you already have the turbo on your bench?
Old Apr 9, 2009 | 11:52 AM
jt371's Avatar
jt371
______
It leaks were the exhaust housing mates to the center section. Very little movement in-out, no side-side. Or was it the other was little side-side, no in-out. Which ever is better that was what i have. Guess I'm worried about the leak
Old Apr 9, 2009 | 11:57 AM
Riffraff Diesel
PREMIUM SPONSOR
Ok, gotcha, just didn't want you to rebuild if you didn't need it. I can get the rebuild kit for you if you want to PM or call me. Have you checked my pricing on the up-pipes? Just hate to see you go to all that trouble just to have to do it again down the road.
Old Apr 9, 2009 | 12:09 PM
Izzy351's Avatar
Izzy351
It's ridiculously easy to rebuild, so depending on how many miles is on yours, you can either do it now, or wait until you HAVE to. If you have no in & out play, it's still good. But for about $100, you can have essentially a brand new turbo. Your call.
Old Apr 9, 2009 | 12:30 PM
SGnAZ's Avatar
SGnAZ
Hey Joe,for my future reference,just how easy to rebuild?
Thanks,Steve
Old Apr 9, 2009 | 12:44 PM
jt371's Avatar
jt371
______
Clay sent you a msg.
Old Apr 9, 2009 | 01:02 PM
Izzy351's Avatar
Izzy351
Have a look at my WebShots pics. I documented my van turbo rebuild there:
Van Turbo pictures from friends & fun photos on webshots
Old Apr 9, 2009 | 08:22 PM
jt371's Avatar
jt371
______
The truck has 125,000 on it now. I bought it in Oct, '08. So not sure about what has or what has not been done for service or repair. I'm game for rebuilding the turbo, just want to make sure I have all neccessary parts before I begin.
