Sponsored by: Real Truck
Towing Magic??
Old Apr 22, 2009 | 04:21 PM
jarrodfeldt's Avatar
jarrodfeldt
I uderstand it was wrong, but it did work. Had we had more time the brakes would have been fixed, but as it stood we needed to move. I belive with the breaks in working order and the truck in good condition, conservitive driveing and you can get it done. My truck is a desil though so its a little different. For me to help a friend i would do it in a hart beat, as for a bussiness. I might start out doing it knowing its just for the short term tell I could do something better. I hear the f550 has a option for a cat desil. that would be what I would prefer.
Old Apr 22, 2009 | 04:59 PM
Carl Lassiter's Avatar
Carl Lassiter
You heard wrong- V10 or 6.4PSD.
Old Apr 22, 2009 | 06:13 PM
Lubbockguy1979's Avatar
Lubbockguy1979
The engine isn't the issue. The issue is braking and towing stability. In texas vehicle that are over 20k total weight fall into d.o.t. And that is a territory where the texas dps will give it to you with out the lube. Seriously though a diesel superduty a v10 or a 5.4 could do the job it is a little out of the weight range to do it safely. If you are in a accident a personal injury lawyer could really do some damage to you in the $$$$ pocket book
Old Apr 22, 2009 | 06:39 PM
cpdorroh's Avatar
cpdorroh
You can get a 7.2 CAT diesel in a 650. Those things are absolute beasts. Funny enough, the standard engine in a 650 is the 6.7 Cummins. I couldn't find the GCWR for a 650, but that would definitely be more in line with what is needed here. Attempting to tow that kind of weight with anything less would be flat out dangerous.
Old Apr 22, 2009 | 06:51 PM
ken kenmnedy's Avatar
ken kenmnedy
go rent the right size truck till trhe money starts to roll in ....but dont haul that heavy you gotta be able to stop and there is allways gonna be idiots
Old Apr 22, 2009 | 08:55 PM
Pinky Demon's Avatar
Pinky Demon
Sorry buddy, but to basically mimic what everybody else here says, way to much load for that truck. You need bigger, much bigger.
Old Apr 22, 2009 | 10:21 PM
GRAY MULE's Avatar
GRAY MULE
i have drove trucks and tow trucks and wreckers all my life and you need to go with a medium duty truck for sure. be safe be careful
Old Apr 22, 2009 | 11:13 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Don't even think about towing that skidder with your F250. You are insane (no offense), and are putting everyone's lives at risk.
Logging usually takes you onto winding, narrow 2 lane roads until you hit a logging road (pun intended) which is worse.
I wouldn't touch that skidder with anything less than a F650. Even so, I think it's at the towing limits of the F650...?
Bluewaterorganicfarm
Jun 13, 2013 07:02 PM
lundman
6.7L Power Stroke Diesel
Aug 6, 2012 11:27 AM
WarriorWithin
Jun 23, 2011 12:39 PM
MiddleNameMUD
43
Mar 26, 2011 01:36 PM
douglpr42
New Member Introductions
Sep 7, 2008 08:41 PM
