Well, not exactly what you might be thinking. No I'm not grilling and no one is driving too close behind me.
I thought since I built my bed for my 55, that I should go ahead and build the tailgate. So today I got a start, 1 1/4" tubing and 1x2 steel, tacked together to form the frame of the tailgate
I cut the center panel out of 16 gage steel.
Spent a lot of time trimming the center panel to give me a flush fit to the 1x2 side sections.
Now all I've got to do is tack the center panel and weld it in solid. The side you see is the inside of the tailgate. When I flip it over I'll try to add some character to the side you will see from outside.
I'll post again when I get it a little further along.
very nice!... I plan on doing the same for mine...My idea was to take the ford scroll from the heaterbox and weld it in the lower corner of the gate...so its a small logo kinda like a newer take with an older flair!
I entertained doing something similar to that, but decided that I would try to work in some interesting character lines instead. I've seen a lot of flat and louvered tailgates and I wanted to do something different.
No, I fabricate anything that I think I can get away with. I've got to justify buying a mig, tig, and gas welding outfit.
I've posted some pictures in my gallery of the bed I fabbed, but the pictures are incomplete due to some problems I've encountered when trying to upload photos. Photos show uploaded but are not there. If I ever figure it out I'll complete the gallery.
I'm with 49fordpickumup are you going to put a couple verticle supports to give it strength in the center sections are maybe roll a bead in it. I wish I had the metal skills you have. Nice very nice
Mr Drewski that looks horrible, just kiddin! keep up the good work and the pics posting, i just love threads like this when someone can build their own truck parts!
Originally Posted by 49fordpickumup
Great work!!Are you going to put a couple verticle supports to give it strength in the center sections? chuck
I had thought about putting in center supports or a rolled bead, but I usually try to do something a "little" different. So that won't be the way I go on this one. Hopefully I won't wind up with a pile of welded up scrap metal. I post it up as soon as I get it to a point that you can look at it and tell where I'm headed with it.
Today hasn't started off very well for me. I sat down at my work table and started stitching the panel in place and ran out of mig wire right off. So I'm off to get more wire and pick up some 80 grit da paper. Maybe I'll get back on it this afternoon.
Looks good, are you using a special Stitch/Body welder?
I have access to a lincoln welder and JC Whitney offers a stitch/Body welder that just simply snap the lead into the the arc welder jaws and you got it for $70.
Was curious if that was requied for body repairs seeing as how I got two rusted fenders that I am tossing around of either using body filler to repair after cutting the rust out or weld in a patch panel.
I was just using a figure of speech for putting in a series of short welds to keep heat build-up to a minimum.
I am however familiar with the item that you refer to from JC Whitney. Eastwood also carries one of those. My wife got me on for Xmas several years back and it did allow welding with a small rod on thin metal without the rod sticking. I was a little surprised because my impression was that it was a "gimmick". However, If you're going to spend $70 and I would advise you to save a little more and watch you local ads for a small 110 volt mig welder. Make sure you buy a brand name like lincoln, miller, hobart. Migs are really easy to set up and use and they are great on thin metal. My wife can even mig weld. With a little practice you'll be on your way. I bought a larger 220 volt mig and it has been one of the best investments I've ever made.
