1978 - 1996 Big Bronco
Pulling Codes on an '86 Bronco
Old Apr 8, 2009 | 05:01 PM
cwlightning03's Avatar
cwlightning03
Hello all. I am trying to pull codes on my '86 302. I have jumpered the self test terminals together (upper right on the large connector and the single terminal on the single wire pigtail), but the engine light does not flash. The light does come on during the key on bulb test, but it doesn't flash when trying to access the codes. Does anyone have a diagram to make sure the wiring to the dlc is ok? Thanks for any help.
Old Apr 8, 2009 | 08:01 PM
alxsnmr's Avatar
alxsnmr
You would have to look in an haynes manual for the wiring diagram. It will also discribe the jumper method for pulling codes on the system as well.
Old Apr 8, 2009 | 09:18 PM
bigunred's Avatar
bigunred
Some times its just easier to get a code reader from the parts store they are only like 20 bucks or so here. they remember the codes they pull and you dont have decipher the flashes.
Old Apr 8, 2009 | 09:36 PM
cwlightning03
I will have to try that. Thank!
Old Apr 13, 2009 | 05:22 PM
SpectreZ91's Avatar
SpectreZ91
Huge fan of the $30 code reader from Kragen/O'riley's
However if you're strapped for cash..
Ford Fuel Injection How To Run a Self-Test
Old Apr 13, 2009 | 07:24 PM
NWBronco's Avatar
NWBronco
I use a volt meter. Sounds like you have the STI connected correctly on the DLG. You should a least see a 1-1 if all checks pass.
Klau
1997 - 2003 F150
Dec 7, 2013 02:45 PM
mjb86
Mar 10, 2013 05:11 PM
Backdraft-14
Mar 17, 2012 05:16 PM
JimmySticks523
1983 - 2012 Ranger & B-Series
Feb 20, 2005 08:06 PM
Billy Ray
Jan 3, 2004 07:57 PM
