Ranger seats
Old Apr 8, 2009 | 04:51 PM
MikeB 88's Avatar
MikeB 88
Ranger seats
My '00 single cab Ranger has the cheap leather seats. 60/40 split bench is what I would call it. I would love to have a console in my truck. what can i use to replace the seats and gain a console? Don't know if it matters, but my truck is a 5 speed manual transmission.
Thanks,
Old Apr 8, 2009 | 06:15 PM
piotrsko's Avatar
piotrsko
apparently the super cabs with kid seats have pretty nice looking bucket seats with about 12" space between them. Or at least the 87/88's did. Junk yard for those.
other options: How much do you want to spend? most aftermarket places can sell you the wildest stuff you ever imagined
Old Apr 8, 2009 | 07:48 PM
Rockledge's Avatar
Rockledge
Your options are limited on account of it being a single cab.
Old Apr 8, 2009 | 08:15 PM
MikeB 88's Avatar
MikeB 88
Thanks, this is something in my mind. Hasn't even made it to the back burner yet. To many other projects first.
Old Apr 9, 2009 | 11:18 AM
5.0B2's Avatar
5.0B2
Try the tech library at therangerstation.com Seat interchange article: Seat Swaps for the Ford Ranger/Bronco II
Old Apr 9, 2009 | 03:12 PM
ttocs388's Avatar
ttocs388
I took the buckets and the consol out of an explorer and put in my ranger. It was a direct bolt in from the seat rails to the consol to the dash.
Old Apr 9, 2009 | 04:35 PM
michigan66's Avatar
michigan66
My truck has a regular cab with the 60/40 split seats. I pulled the driver's seat out and cut the middle "seat" off. It took a little work and imagination to deal with the extra upholstery but I was able to trim it back and set a console unit between the two seats. That gives me two can holders and cubbies for other stuff.
I have no idea who could sit in that seat if the driver and passenger seat were both occupied by adults. The floor shift makes even worse.
Old Apr 9, 2009 | 05:03 PM
Rockledge's Avatar
Rockledge
That works for the extended cab, but not the single cab.
Old Apr 9, 2009 | 05:17 PM
MikeB 88's Avatar
MikeB 88
Now that is an idea. I'll have to keep this trick in the back of my mind.
Thanks,
Old Apr 9, 2009 | 10:21 PM
ttocs388's Avatar
ttocs388
What won't fit?
Old Apr 10, 2009 | 10:28 AM
5.0B2's Avatar
5.0B2
Explorer seat backs don't fold forward - unless you find some from a 2dr Sport.
Old Apr 10, 2009 | 05:43 PM
blueranger103's Avatar
blueranger103
i have a 2000 ranger single cab with 60/40 cloth seats with a console your best bet is to find just the driverseat at a junk yard with a console on it and possibly match the upholestry up. the 60/40 seats from a ext cab ranger don't fit so dont try ( found that out the hard way) and the brackets are the same for single cabs from 98 to 03 then they changed i just replaced then entire bracket assembly because this little plastic part on the inner track broke. try the junkyard though i got a seat for 10 bucks. good luck oh yeah the entire 60/40 seat assembly is about 2000 dollars and the console by its self is about 220 so buy used and save
Old Apr 11, 2009 | 01:05 AM
ttocs388's Avatar
ttocs388
Yes they do. The 4 door versions will still move forward although they do not release the seat track and slide forward automatically(mine is this way). The 2 door versions will unlock the seat track with the same lever pull. The consol doesn't go any further back then the seats so I don't think it would be too long.
