EBPV as brake
Old Apr 8, 2009 | 02:09 PM
12ozd's Avatar
12ozd
EBPV as brake
I saw somewhere on here about using the EBPV as an exhaust brake.
I can't find it .
Who's done this?
How does it perform ? Worth the effort?
Assuming it would work better on a manual vs. auto?
Old Apr 8, 2009 | 02:32 PM
canuckelhead's Avatar
canuckelhead
I'm interested too, 12ozd. My upcoming tuner will have that program but I have little experience or knowledge in its operation.
I'm sure someone will be around soon, we've come to the right place for the answer.
subscribing
Old Apr 8, 2009 | 02:44 PM
superduty4x4's Avatar
superduty4x4
You can do it one of two ways:
1. Wire the EBPV onto a switch
2. Get a decel tune from Jody at DP Tuner
It won't work like a "real" exhaust brake, but it does help from what I've read. I still need to do it to mine
Old Apr 8, 2009 | 02:45 PM
ron's power stroke's Avatar
ron's power stroke
i used mine as a brake for 2 years..not quite as good as a real exhaust brake but better then nothing..
https://www.ford-trucks.com/forums/2...brake-mod.html
Old Apr 8, 2009 | 02:51 PM
gtnwood's Avatar
gtnwood
I have an exhaust brake on my 2000 F350 Dualie and I hardly notice the diff. is that because it is an automatic?
Old Apr 8, 2009 | 03:00 PM
ron's power stroke
if the TC is un locked the brake wont hold the truck back..only way around that is to do the TC lock mod..i had a little box from SP diesel that locked and unlocked my TC what ever speed i wanted from 22 MPH and up..it would then let me turn on my exhaust brake.. every thime i let off the go peddle the brake would come on..
Old Apr 8, 2009 | 03:08 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I have the decel tune and I can tell it slows down the truck. My TC don't unlock untill right at 20 mph. I can also hear when the EBPV closes.
Old Apr 8, 2009 | 04:07 PM
King0581's Avatar
King0581
I use my EBPV as a brake. It held back alot better when I still had the stock exhaust but now with the 4" it doesnt hold back as well. It does still help though. I have a 6 speed so the TC lock up was not an issue.
Old Apr 8, 2009 | 04:10 PM
canuckelhead
Good to hear that the tune will do the deed.
Thanks for the info and thread link.
Old Apr 8, 2009 | 06:42 PM
StanleyZ's Avatar
StanleyZ
Look on ebay or on your browser for SP Deisel, The one I have is a three way switch. One way is off, one was is the ebfv on (closing when you take your foot off the accelerator) and the third way is a TC lock up and the ebfv on. The only problem for regular driving is that the TC unlocks at around 35 MPH unless you lock and unlock in with the switch. If you leave it locked down to a stop the truck will stall, just like if you forgot to put in the clutch on a stick. The price was very reasonable and the install took a couple hours. I only use mine to come down steep downgrades when I'm towing. It's very useful for that but I keep thinking I'm putting too much stress on that valve. No problems though. I think some of the later models may be more complex and have better features so don't go entirely by this, visit SP. Hope this helps.
Old Apr 9, 2009 | 08:47 AM
milleroutdoors's Avatar
milleroutdoors
I recently installed a DP with the decel tune. I am happy it really holds you back on the hills, really noticed when towing.
Old Apr 9, 2009 | 08:58 AM
ghig1967's Avatar
ghig1967
Glad to hear that. I to have the decel tune, but haven't had the chance to tow with it yet. I do like the response it gives. Although not as aggressive as a jake brake, it definately helps.
Old Apr 9, 2009 | 09:01 AM
Kwikkordead's Avatar
Kwikkordead
I've done it too and it really makes a big difference towing a heavy trailer that wants to push you down hill.
Saves the brake pads a lot.
