Brakes
Old Apr 8, 2009 | 01:59 PM
iowastroker's Avatar
iowastroker
Brakes
Does anyone out there have a jake brake in there truck and if you do were did you get it. It no has do you know where it get one and is it worth it.
Old Apr 8, 2009 | 02:14 PM
Diesel_Dirk's Avatar
Diesel_Dirk
Quoted from the Jacobs faq:
FAQ4:
Do you make a product for the Ford 7.3L Powerstroke or Navistar International T444E engines?
ANSWER:
No, Jacobs does not offer an exhaust or engine brake for these engines in fact, Navistar and Ford have requested that we do not develop one for these engines.
The primary concern with putting a retarder on these engines is their use of hydraulic lifters. Most engines with hydraulic lifters have fairly low exhaust back pressure limits so the performance of an exhaust brake would not be substantial. More importantly the use of an exhaust brake on an engine with hydraulic lifters can cause engine damage. The problem is that the increased back pressure resulting from the operation of the exhaust brake will cause some degree of valve float. This valve float can cause the hydraulic lifter to re-set with the valve still open (not seated). This phenomenon is known as lifter jacking. Lifter jacking could also result if a traditional engine brake were used on these engines. The results of lifter jacking can be anything from low positive power (because the valves stay open) to engine damage caused by valve to piston contact.
What some people here do is hook up a manual switch for thr Exhaust backpressure valve (might not be the correct name...)
Since this is a factory installed component it should be fine.
Old Apr 9, 2009 | 02:53 PM
DRRXR's Avatar
DRRXR
Best fit however know the pro's and cons beforehand
Jacobs only manufactures for Cummins
Here is your best bet.
BD Power - Product: 7.3L BrakeLoc
One more thing if your towing more than 7k there is not a noteable difference than not having one.
Old Apr 10, 2009 | 10:18 AM
plowhand's Avatar
plowhand
Playing in the Dirt
Jacob's make brakes for Caterpiller, Cummins, Detriot, International and Mack, that I know of. Of course not every engine that each of them make.
Old Apr 10, 2009 | 11:12 AM
Brown Falcon's Avatar
Brown Falcon
With these motors a exhaust brake doesn't really make a whole lot of difference unless you're at higher RPM's... once it drops back down to lower RPMs you won't noticed much
Old Apr 10, 2009 | 11:58 AM
iowastroker
so really not worth trying to put one in
Old Apr 10, 2009 | 12:00 PM
rideracelivemx7's Avatar
rideracelivemx7
turn your ebvb valve into one
Old Apr 11, 2009 | 09:33 PM
believer45's Avatar
believer45
Not worth a Jake Brake (to get that BRRRRRRRPPPPP!! like the big trucks) but it is worth it to do an exhaust brake. Just be aware you have to have the engine RPMs up for it to do any good.
Dave / Believer45
Old Apr 11, 2009 | 09:56 PM
cowmilker08's Avatar
cowmilker08
since i put my ebpv on a switch and played with it alittle, it works best in 3rd gear (E4OD) above 25mph, if in OD rpm under 1200 then not noticable.
bad_habit59
Feb 12, 2009 12:20 PM
ac91725
1983 - 2012 Ranger & B-Series
Feb 21, 2008 07:30 PM
imlowr2
Sep 15, 2004 09:08 AM
c96drumm
Garage & Workshop
13
Apr 22, 2004 08:31 PM
djj1967
Aug 10, 2003 09:57 PM
