Ah the art of destructive chemistry. Brake fluid and battery acid does good to. Here in the northwest our recyclers take anything that was derived from oil as oil.
Brake fluid is not derived from oil, it's more similar to antifreeze than oil. I know our recycling center actually burns it off.
I dump it into my used oil and take it to Autozone to get rid of it. With what I see that goes into the oil there, like leafs, RTV, dirt, rocks, etc. I do not think a small bit of brake fluid hurts. Anyways, how much anti-freeze do you think is in that oil after a blown head gasket? I would dump it into the used oil and not worry about it, it will be burnt off someplace.
Yeah, what surprised me is when I went down to the local recycling place (with about 20 gallons of oil and 7 of antifreeze), the guy said to just dump it all into the oil tank and the recycle process would separate it out. I thought I had remembered at one other point they strictly said not to put antifreeze in the oil tank. Who knows. The recycle process probably depends on what kind of equipment they have whether or not they can get glycol stuff out of it.
My father in law is a retired Class A mechanic. He taught me one added use for brake fluid. If you are trying to take a tire off a rim and cannot break the bead, lay the tire flat on a level surface and fill the grrove around the bead with brake fluid - used stuff will do. Let it soak for at least 30 minutes. The bead will break much easier. Of course, you may have to repaint the rim...
most garages and deale3rships just drain it into oil along with tranny and gear fluid the only thing thing that dont get tossed into the oil is antifreeze.
It kind of depends on what the used oil is used for. If it is just used for hydrocarbon feed stock in a refinery it will be filtered, the water boiled off and the rest broken down just like crude oil. Sometimes the used oil is used for heating and it needs to be fairly clean and pure for that.
