Help Dead Truck
Old Apr 9, 2009 | 06:37 AM
Byrddog's Avatar
Byrddog
HPOP reservior, where exactley is that located?
Ive never really messed with the HPOP before.
Do you guys think FORD will have the black CPS or do you think ill have to find one online?
Old Apr 9, 2009 | 06:45 AM
Byrddog's Avatar
Byrddog
OK ford has no black CPS only gray but good news is there only like $20.
I guess if it s not the prob ay least ill get an extra for cheap.
Old Apr 9, 2009 | 06:57 AM
fishmanndotcom's Avatar
fishmanndotcom
Originally Posted by NWBronco
All I can say is mine did. Others will surely chime in. The other thing is to check the HPOP reservior and make sure it's full.
Originally Posted by RÖENTGEEP
I would try with a BLACK one and check the HPOP as stated above.
YES!!!!!!!!!!
CHECK YOUR OIL!
even if your truck is full of oil, if it is old it may be too thick to travel through the injectors! when did you last change it?
this is the most overlooked problem! i went for 3 days of no truck before finding out my oil level was low and my injectors were not firing!
the hpop is between the alt, fuel canister/filter, AC compressor, and coolant hose. it has a wire loom running on top.
http://inlinethumb04.webshots.com/30...600x600Q85.jpg
-cutts-
Old Apr 9, 2009 | 07:21 AM
Byrddog's Avatar
Byrddog
Thanks fishman, i know where the HPOP is but how do you check the reservior?
Oil is right on the full mark on the dipstick.
Old Apr 9, 2009 | 07:30 AM
fishmanndotcom
there is an allen head plug on the top be careful not to lose it! open it up and look down, if you cant see the oil then top it off. it should be within an inch from the bottom of the threads. if you cant open the plug i have been known to fill through the sensor hole on the other side of the top of the cover!
good luck man!
-cutts-
Old Apr 9, 2009 | 08:15 AM
Byrddog's Avatar
Byrddog
Thanks man, i sorta figured it was that plug. just wanted to make for sure.
I went ahead and got a new CPS as well ($22).
Ill let you guys know what happens, keep your fingers crossed.
Old Apr 9, 2009 | 10:39 AM
Byrddog's Avatar
Byrddog
Update: Check HPOP oil is full; Installed new CPS; Installed new fuse 22 and unplugged fuel heater; Put new fuel filter in and checked to see if fuel bowl was filling and it is.
Still the same thing, sounds like its just about to start but wont!
Old Apr 9, 2009 | 11:35 AM
RedOnRedPowerStroke's Avatar
RedOnRedPowerStroke
Has the GPR been ruled out because it was replaced last summer? Was it a loud backfire, or a misfire? The one thread I found on another forum they talked about the GPR causing backfires when they are bad/failing?
Old Apr 9, 2009 | 12:44 PM
Byrddog's Avatar
Byrddog
I did the arch test and, there is an arch but still not starting.
Im thinking maybe the wiring, last summer everyonce and a while when i would start it, it would start but have no power and sound like only a few of the injectors were firing. I would shut it off and start it again and all was fine. A few weeks later i was coming home from the lake and suddenly lost power, it would still be running but i could have pushed it faster than it was moving. I found the bad spot (or so i thought) the plug that gos into the valve cover off the main wiring harness, cut the plug off and put on a new plug. Everythings been fine since Sept.
The other morning when i started it, it started that same way, i shut it off and all was fine until the next day. I had started and stoped 3x and it started fine every time until i was going down the road and it started to lose power and died.
Old Apr 9, 2009 | 04:39 PM
Byrddog's Avatar
Byrddog
Well I pulled the valve covers just to make sure the wires in there looked ok, and its all fine looking in there.
I guess next is a new wiring harness under the hood.
Unless anybody has anyother ideas???
Old Apr 10, 2009 | 03:36 PM
Byrddog's Avatar
Byrddog
Would a bad IPR casue the truck not to start?
97 silver 4.0
1983 - 2012 Ranger & B-Series
Sep 27, 2021 10:07 PM
darkestskydiver
3.8 & 4.2L V6
Mar 20, 2013 06:08 PM
strokin'_tatsch
121
Jan 30, 2013 08:57 AM
dakota-boy
Jan 24, 2009 02:37 PM
85rangerman
Feb 1, 2003 01:19 PM
