Helppppppppp Charging problems...:(
Old Apr 8, 2009 | 11:29 AM
PsD007.3's Avatar
PsD007.3
ok just tested the battery's when truck is not running they tested at 12.75 then i started truck and tested and turned on highbeams, and heater on high and both tested at 12.36, when i test the wire on the back of the alternator it also is reading 12.65..soo whats wrong here guys??? alternator and battery's are both brand new about 1hr old...
<!-- / message --><!-- sig -->__________________
Old Apr 8, 2009 | 11:41 AM
12ozd's Avatar
12ozd
Sure sounds like an alternator to me.
Did you get a reman? I have installed many "new" bad alternators.
Or you have a very high current draw. (unlikely w/ what you said you had on)
Did you wait for the glow plugs to complete their cycle?
They typically stay on for a short time after the light goes out.
Also, what happens when you elevate the idle?
Old Apr 8, 2009 | 11:43 AM
PsD007.3's Avatar
PsD007.3
its a reman alternator and had it tested before i put it on in autozone and it passed on there bench tester and i did this test after i had the truck running for about 5 minutes elevating the idle it stays the same...what else in this system could it be??? this sux
Old Apr 8, 2009 | 11:52 AM
12ozd's Avatar
12ozd
Belt good condition,proper tension?
Pulley on tight?
Personally,If it were me,I would get another alternator.
I realize autozone tested it and it was fine,I don't have a lot of confidence in that.
I would not get an autozone one myself.
Try a different one, if that dosen't fix you up,.
IIRC thats about it for the charging system on these trucks.
Old Apr 8, 2009 | 11:53 AM
mndiesel's Avatar
mndiesel
mine had the same reading and it was the diode that was bad in the altenator.
Old Apr 8, 2009 | 01:02 PM
PsD007.3's Avatar
PsD007.3
i think i found what it was the loom of wires that run down to the starter were what looked to be rubbed through on the metal battery tray and shorting out, and i moved it and my volts shot up to 14.3 i'm guessing that was my problem...would that cause the alternator to not put out though??
Old Apr 8, 2009 | 01:13 PM
12ozd's Avatar
12ozd
If you have a bare wire touching metal,that would be a dead short and a very high draw,however,if thats the case,you're lucky you didn't have a complete meltdown/battery explosion.
I'm assuming a cable,otherwise it would have been fuse protected.
If you isolate the wire,and it's now charging,you're good to go.
repair / replace .
Old Apr 8, 2009 | 01:19 PM
PsD007.3's Avatar
PsD007.3
yea i wire tied it up out of the way idk why that happened i'm guessing over time it just kept rubbing the metal withe the motor vibration and wore a small bare spot
Old Apr 8, 2009 | 01:26 PM
superduty4x4's Avatar
superduty4x4
I would buy some split loom or heater hose that is big enough to run the battery cable through to protect it, then wire it up away from the batt tray. You got lucky that you didn't have more problems, like a burned up truck!
Old Apr 8, 2009 | 01:31 PM
PsD007.3's Avatar
PsD007.3
yea tell me about it, i mean i'm guessing thats what it was i moved the wires away from the battery tray and my volts shot up to 14.3 soo that be my guess...
Old Apr 8, 2009 | 01:32 PM
superduty4x4
I would agree... that dead short was not doing you any favors.
Old Apr 8, 2009 | 01:52 PM
PsD007.3's Avatar
PsD007.3
ok i'll keep you guys updated thanx alot
Old Apr 8, 2009 | 02:02 PM
SpringerPop's Avatar
SpringerPop
Got any photos detailing exactly where this problem occurred?
All of our trucks are almost identical to yours and could develop the same problem.
We need to know where to inspect.
Thanks,
Pop
Old Apr 8, 2009 | 02:06 PM
PsD007.3's Avatar
PsD007.3
i could take a pic but i suck at uploading figuring out how would take forever, i'll try to explain, ok on the passenger battery,, if you follow the positive wire it will drop down over the rear corner of the battery if you follow it down you will see the corner of the battery tray, thats right where mine was rubbing...
Old Apr 8, 2009 | 03:41 PM
rbaker6336's Avatar
rbaker6336
You seem to have found the problem,but I would check the wire a bit closer to see if it was rubbed or burned to where you may have a open circuit,by moving the wire you may have caused a temporary reconnection
