Clutch safty switch
Old Apr 7, 2009 | 10:07 PM
dads89f150's Avatar
dads89f150
Clutch safty switch
Hey everyone, new to the forum. I have a 89 f150 with a 300 and 5 speed, well something has happened, in order to start it the clutch pedel has had to go farther and farther before it cranks, now you have to stand with all your weight to get it to start. I replaced the switch and that made no difference. Any advice???
Old Apr 8, 2009 | 05:13 AM
Lazy K's Avatar
Lazy K
Check around the firewall where the master cyl mounts for cracking/flexing and also check the pedal pivot for wear.
If the firewall is flexing there is a repair plate you can get.
However I would advise you to scroll up from here on the main page and you will come to the `87-`96 F Series page. I would post this problem there and you will get plenty of help. But check out what I said.
Hope this helps.
Freedom1955
2015 - 2020 F150
13
Aug 29, 2016 05:41 PM
Chris611
6.7L Power Stroke Diesel
Apr 4, 2014 09:37 AM
wdsloot2
Jan 16, 2014 02:47 PM
Cenzo777
Nov 13, 2005 09:43 PM
mooktank
Offroad & 4x4
Jan 16, 2003 05:51 AM
