Automatic refill...???
Old Nov 12, 2005 | 12:11 AM
Cenzo777's Avatar
Cenzo777
My 91 f150 has dual gas tanks, one of which (the rear one) I never add fuel to because it leaks after a certain level. I will fill up my front one and drive till i need to fill up, and when i switch to the rear tank there is usually about 1/4 tank of gas....? I'll drive that till the fuel guage is on E, and then a little farther to make sure i have little to no gas in there. I switch back to the front tank, refill, and drive. There is always at least 1/4 tank of gas in the second tank after ive been driving several hundred miles. Any explinations?
Old Nov 13, 2005 | 05:27 PM
LxMan1's Avatar
LxMan1
Yep, if the truck uses a switching solenoid on the frame, is isn't shifting completely. If it doesn't have one of those, then the one way valves in the rear pump assembly are bad allowing fuel to be pumped from the front to rear tank.
Old Nov 13, 2005 | 09:43 PM
Cenzo777's Avatar
Cenzo777
And i was hoping it was divine intervention! That explains the bad gas milage too. I'll look into those two possibilities.
Jammer-1
Apr 14, 2017 09:43 PM
khaitan
28
Dec 3, 2016 08:38 PM
djmichael24951
Apr 1, 2016 07:48 PM
eds72
Jul 14, 2015 08:25 AM
my93
Nov 7, 2004 07:25 PM
