Having charging problem again
Old Apr 28, 2009 | 12:21 PM
ford freq's Avatar
ford freq
Yes i have a neg battery cable going to the engine(starter),could it be a bad connection at one end .i will check the cable to find out
Old May 4, 2009 | 12:57 AM
ford freq's Avatar
ford freq
Changed neg battery cable to the engine,found it was split where it was clamped to the frame.Started the engine and the gauge moved a little into the middle,but batt light is stll on.I have had the alternator tested a few times already but i think i need it done again.had it done twice by two different places and they said it was ok!?
Old May 4, 2009 | 01:13 PM
JD IN NJ's Avatar
JD IN NJ
Had problem with friends 93 150 6cyl. not putting out more then 13v. with rebilt alt.Long story short it turned out to be the old silicon on the output plug of alt. Very small pieces got inside the connecter, with a small wire I cleaned it out and it charged at 14.3
Old May 6, 2009 | 01:28 AM
ford freq's Avatar
ford freq
Turns out that one of the plugs was replaced going to the alt,found that the connections inside were damaged and i guess not making contact to get enough volts through,i never would have thought of that.,thanks JD
guisepi
Jul 1, 2024 01:20 PM
sunuvabug
Jun 22, 2024 01:58 PM
cree92831
18
Oct 9, 2013 03:14 PM
Bronco_Coop
1978 - 1996 Big Bronco
May 8, 2009 08:12 AM
SHADES
Sep 27, 2005 12:26 PM
