back lights and door locks not work
Old May 6, 2009 | 01:28 PM
jaggerjack's Avatar
jaggerjack
hi, i have an expedition 98, and i have a problem, recently the back lights (reverse) not turn on when i go on reverse direction and the door locks not work when I begin to drive, the door locks only work with the alarm switch and the door switch. I have checked all the fuses and they're good, so i don't have idea what can be the problem, if you can help me i will thank really.
Excuse my english but i'm mexican. Thank you guys
Old May 6, 2009 | 01:43 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
If you have an automatic transmission, the reverse lights problem is probably the MSLP (neutral safety switch) on the drivers side of your transmission. It will have to be adjusted. It MIGHT also be the other problem too.....
Old May 6, 2009 | 01:54 PM
jaggerjack's Avatar
jaggerjack
ok i get it, but what means exactly MSLP and where can i take it to be adjusted almost ford service
Old May 6, 2009 | 03:51 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
You SHOULD be able to do it yourself....use the "search" function and try to find it. Maybe someone here will let you know.
Old May 6, 2009 | 04:09 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
MLPS (Manual Lever Position Sensor) Sorry, got the initials wrong. You should be able to do this yourself...it's just alligning the lever on the side of the transmission. Amybe someone here has access to the exact procedure for your vehicle.
Old May 6, 2009 | 04:10 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
By the way, did you check for fuses UNDER THE HOOD?
Old May 6, 2009 | 04:19 PM
jaggerjack's Avatar
jaggerjack
thanks for the information, and yes i did it, and i didn't find something wrong, but I'll try it again and I'll check the neutral safety switch too
