broken bell housing
Old Jan 15, 2003 | 09:23 AM
supersport8's Avatar
supersport8
broken bell housing
I have a 97 F450 SD with the powerstroke diesel and 5 speed tranny. The clutch wouldn't disengage so when I checked it out I found that the bell housing had broke completely from the rest of the trans!:-staun Has anyone else had this happen and what could have caused this??
Old Jan 15, 2003 | 08:52 PM
2Wise4aGM's Avatar
2Wise4aGM
broken bell housing
I have seen it happen before. Usually the Dual mass flywheel goes bad.(You should be able to feel a vibration in the truck when this happens). The vibration literally shakes the tranny so bad that it busts the case. We have three trucks at work that have done this. I usually replace the dual mass flywheel with a solid one, but if you do you will need a different clutch. I have also gotten really quick at rebuilding ZF 5 speeds
Old Jan 16, 2003 | 07:21 AM
supersport8
broken bell housing
Thanks for the advice. I think I will go to a solid flywheel, at $1900 a pop for the tranny it seems the best way to go....Thanks!!
Old Jan 16, 2003 | 07:46 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
broken bell housing
willys392
Nov 7, 2015 07:21 AM
greyhound
1961 - 1963 F100 Unibody
Apr 19, 2015 08:25 PM
76WYOF250
Jul 10, 2014 02:12 AM
F-250 restorer
Jul 2, 2014 05:26 PM
