hi just check e-bay i see one on their for 9.99
never seen one before it looks like a tee 5/16-24 thread 2.75" and the cross 1.925 ????? check out I just google 1950 f1 truck good luck David
There's nothing magic about the spring, other than it's pretty stiff, and it can't be over a certain diameter and still get thru the window frame into the door. Do you have the other one? True Value here has a good selection of springs that could be cut down. The washer is so the end of the spring doesn't hang up on the frame. A nylock nut would be best. I have a decent picture if you need it.
I could try the hardware store, just trying to keep it correct. Does anyone know if the kit for the newer years would work? Who sells them to look at? Please bare with me this is for a buddy and I haven't seen the peice yet. Just beibg told what he needs.
Reason: left something out.
Well, you'll need more than just a spring and a nut. The upper washer that goes on the shaft but inside the "loop" under the frame is tear drop shaped and has a square hole in it. That's what prevents you from opening the window two far. Then in progression downward, there is a slip (thin and wide) washer, the spring, another slip wahers, then a regular cut washer and a castleated locking nut.
I'm not sure what the kits include, but in the drawings of the various vent windows the pieces and th enumber of pieces are different. I'll do a little more research and get back to you. Mine are currently out of the truck so I can get some good photo's for you as well.
Here's the complete assembly. The thick spacer has a square hole in it, it turns with the window. The pointed pece is the travel stop, also has a square hole. There is a thin brass washer between the spring and the frame, that needs greasing.
