Frame Question Again!!
What are you going to use-POR or paint?
All I am using is a flop disk 60grit and it takes it right down to bare metal.
And is fast just about got the out side rails and under the frame done on the one side next is the other side and then start in side of the frame.
I am going to take that cross member out today or tomorrow.
Will have progress pictures tonight.
Cheers
Heres some pictures of what I got done today.
<a href="http://s714.photobucket.com/albums/ww148/ChrisCrash12/?action=view¤t=framegrinding3.jpg" target="_blank"><img src="http://i714.photobucket.com/albums/ww148/ChrisCrash12/framegrinding3.jpg" border="0" alt="Photobucket"></a>
<a href="http://s714.photobucket.com/albums/ww148/ChrisCrash12/?action=view¤t=FrameGrinding4.jpg" target="_blank"><img src="http://i714.photobucket.com/albums/ww148/ChrisCrash12/FrameGrinding4.jpg" border="0" alt="Photobucket"></a>
<a href="http://s714.photobucket.com/albums/ww148/ChrisCrash12/?action=view¤t=FrameGrinding5.jpg" target="_blank"><img src="http://i714.photobucket.com/albums/ww148/ChrisCrash12/FrameGrinding5.jpg" border="0" alt="Photobucket"></a>
<a href="http://s714.photobucket.com/albums/ww148/ChrisCrash12/?action=view¤t=FrameGrinding6.jpg" target="_blank"><img src="http://i714.photobucket.com/albums/ww148/ChrisCrash12/FrameGrinding6.jpg" border="0" alt="Photobucket"></a>
Now should I run out and get some primer to cover the area I got done? Or will it be okay for another day or so till I finish up..
Cheers
Now its at this point should I get a wire twisted cup and go over that?
Or just leave it where its at with the flop disk?
Cheers
just wondering will it be okay to wash the frame with my pressure washer to get all the dust/dirt crap off the frame before paint? I was thinking of blasting it in the am, letting it dry all day then a very light sand and then paint end of the afternoon?
What do you use to wipe the frame off? Before the paint to make sure its clean?
Cheers
Prior to painting, I break out a bucket with a liberal dose of dish soap and water and go to town with a scrub brush and a toothbrush. I really apply the elbow grease and make sure to get all the little nooks and crannies. Then primer once it is dry.
I finished it up today. Put the paint on now waiting for it to fully dry.
Tell me what yall think.
Cheers
<a href="http://s714.photobucket.com/albums/ww148/ChrisCrash12/?action=view¤t=FrameFinished2.jpg" target="_blank"><img src="http://i714.photobucket.com/albums/ww148/ChrisCrash12/FrameFinished2.jpg" border="0" alt="Photobucket"></a>
<a href="http://s714.photobucket.com/albums/ww148/ChrisCrash12/?action=view¤t=FrameFinished3.jpg" target="_blank"><img src="http://i714.photobucket.com/albums/ww148/ChrisCrash12/FrameFinished3.jpg" border="0" alt="Photobucket"></a>
<a href="http://s714.photobucket.com/albums/ww148/ChrisCrash12/?action=view¤t=FrameFinished1.jpg" target="_blank"><img src="http://i714.photobucket.com/albums/ww148/ChrisCrash12/FrameFinished1.jpg" border="0" alt="Photobucket"></a>
<a href="http://s714.photobucket.com/albums/ww148/ChrisCrash12/?action=view¤t=FrameFinished.jpg" target="_blank"><img src="http://i714.photobucket.com/albums/ww148/ChrisCrash12/FrameFinished.jpg" border="0" alt="Photobucket"></a>
I am going to do small touch ups today that I could not get with the grinder I bought a small dremal to get those.
Its looks good I think.
I am going to over coat it with a semi gloss black.
When can I wash my frame? couple days or when after the paint has been put on.
Also My dumb *** forgot to take out that crossmember on that so the rivets are still.
I am going to try to get it out from the inside but may have to do it from the frame.
So will the patch match up? Even with the finish coat I am going to put semi gloss on so it should even up later right?
And what is the best way to get these damn rivets out?
Cheers
