Replacing dash instrument cluster light bulbs??
Old Apr 6, 2009 | 07:46 PM
scholzee's Avatar
scholzee
2001 Expy any tips or part numbers on how to replace instrument cluster light bulbs ?? Most are on but about 0 - 3000 rpm on the tach are out. Thanks for all replies!!!
Old Apr 6, 2009 | 08:02 PM
alloro's Avatar
alloro
Not sure of the bulb number. When I replace some of my bulbs I do remember that twisting out the bulb holders was something you had to be careful with. In theory they're supposed to just twist left 1/4 turn. The problem I had was the 2 tiny plastic clips that hold it from turning didn't want to let go. If you forcibly twist them you might break them. I use a utility knife blade to lift them a bit before twisting the bulb holder out.
Old Apr 6, 2009 | 09:23 PM
scholzee's Avatar
scholzee
Thanks for your help , any advise on getting the cluster out are there tons of screws or is it easy.
Old Apr 6, 2009 | 10:00 PM
alloro's Avatar
alloro
Removing the headlight switch is the worse part. Once that switch is out, I can have my cluster in my hands in less than 10 minutes. Just be careful pulling off the plastic dash trim ring or it will crack. I use a putty knife and slip it behind the trim ring to work it loose. There's only 4 torx head screws holding the cluster in once the trim ring is off.
armored
Dec 10, 2022 10:19 PM
grunt5252
Mar 9, 2013 07:55 AM
LARIAT 85
Aug 15, 2012 06:20 PM
neufelda
1983 - 2012 Ranger & B-Series
Mar 31, 2004 08:21 AM
Kevin
Jan 4, 2000 12:19 PM
