Last week JD started the "what mods do you have" thread... now its time for "what mods do you have on the shelf?" I'll start:
Pro Comp 2" shackle level kit
Get stock track bar modded to be adjustable
5" MBRP exhaust tips
Try to re-adjust passenger side tail pipe down to match driver's side
AIC install
GPR LED
6.0 trans cooler (w/tranny flush and hopefully a JW VB install)
Clean intercooler out
Replace CCV hose
Hutch/Harpoon (not looking forward to dropping my 50+gallon tank)
New up-pipe gaskets (thanks Ron!)
I think there's more, but that's all I can think of right now.
great idea Chase...i got a few more LED's to put on and 910 valve spings to put in but waiting for push rods first...i just started cleaning my shelf of old parts to make room for the mods that are on the way..
R and R the driver's side hub and needle bearing.
White LED lights that come on when you enter and exit - shine on the steps of the running boards/bars.
Utility Lights for the bed.
Not necessary "on the shelf" yet because I need to buy them...
But I need to replace my sway bar links
WW
another good thread would be how many little fix up or finishing things have you put off..its funny how winter slows you down and things slide by...summer time its fixed as soon as it breaks or get put on as soon as the brown truck shows up
R and R the driver's side hub and needle bearing. White LED lights that come on when you enter and exit - shine on the steps of the running boards/bars.
WW
Take pictures Chris, I may what to copy your ideal of this mod to.
You guys are reminding me of the crap I was forgetting!
Hook up EBPV on a switch
Get/install new sway bar bushings
Fix that effing squeak in the steering wheel
Windshield needs replaced
I won't even get started on the "I'd sure like to do that someday" list...
-Marineco plug for the block heater (had that since the first of Jan. just haven't gotten around to installing yet)
-Regulated return, waiting on a delivery from ITP, should be here tomorrow, and then I will have all of the parts together for it. Then I just need to get the brackets made for the filters under the truck and get some bolts for that as well.
-Schaeffer's transmission fluid
-Schaeffer's gear oil
mine too..things are going to start getting fixed this weekend..I cant put them off any longer...spare tires in the back of the truck..not under it..U joint has been vibrating for a couple months now..U joint on the front axle needs to be replaced..vacuum pump needs to be replaced..even if it only runs my heater..wires to tie up that fell down do to snow and ice.the list goes on and on..
You consider adjusting the height of the exhaust pipe, new Up pipe donuts and cleaning the intercooler mods? Thats maintenance
Anywho, i have some steel pipe on the floor, some johnny joints on the way, and i chalked out some shapes on piece of 1/4" plate i dropped off to get cut out today, next weekend i should have them all tacked together
exhaust tip and IC cooler cleaning would be finishing a mod..you got me on the donuts though..now that i see it in his post ..i need to say glad to help you out Chase
Will do, I just need to find the correct lights that suit my fancy. Believe it or not, the little ghetto ricer lites from Autozone may be a suitable candidate for this. Kind of like the ones that mount to the windshield washers or something similar. I figure I can tie into the dome light so when I click my key fob and the lights come on, the steps can be lit as well.
