Rust on my 06
Old Apr 6, 2009 | 11:31 AM
MichiganHunter's Avatar
MichiganHunter
Rust on my 06
ok I just noticed some bubbling in a few spots on my hood, it is where the grill meets the hood, Has anyone had a issue with this? Does anyone know if this would be covered under Warranty? Hope someone can help me out, Thanks.
Old Apr 6, 2009 | 11:59 AM
cullenkyla's Avatar
cullenkyla
Yes it should. Thinking its 5 or 6 yr. and or 100,000 miles. Check with your dealer. Hope this helped.
Old Apr 6, 2009 | 06:20 PM
spatts's Avatar
spatts
Rust ???? Are you shure ????? I believe the hood is aluminum !
Old Apr 6, 2009 | 07:11 PM
mercman86's Avatar
mercman86
x2 on the hood being aluminum. Not sure how the bubbles could be caused by rust, I noticed rust bubbles on my right rear wheel well in the vicinity of where a "buthyl pad" was replaced that could cause that. Took it in because i knew that there was the 5 yr 100,000 mile warranty against corrosion. They told me that it wouldn't be covered because the bubbles that i saw were not caused by rust, but "at the factory someone hit it with an aluminum hammer and a small fleck of the hammer got stuck to the steel and after it got painted it takes 4 years for the dis similar metals to react to each other". Thats what the service manager told me. If i wanted it fixed i would have to pay my self. I ended up fixing it myself and it looks flawless. Unless your dealer really likes you, be prepared for somthing like this.
Old Apr 6, 2009 | 07:12 PM
efx4's Avatar
efx4
Are you sure the bubble isn't a paint blemish? Your hood is made of aluminum, although aluminum can corrode. I've been an automotive painter for more than 22 years, and I've yet to see any corrosion or perferation on any later model F-150 hood to date.
Old Apr 6, 2009 | 07:22 PM
bridge's Avatar
bridge
Sick 'n Tired
If my dealer tried to run a load of BS like that past me it would be on like Donkey Kong. I would go back in there with a camcorder and asked them to document that response. "And while you're writing out that reason please make sure to write down the name and number of the regional Ford customer service rep, I'd like to get the official word form Ford on your metalurgic evaluation and rational."
Old Apr 6, 2009 | 08:59 PM
stanger_missle's Avatar
stanger_missle
Ford knows its a problem. It is iron contamination under the paint. The dissimilar metals corrode the aluminum. The paint will not stick to the corrosion and flakes off. Our 2004 Explorer has it really bad on the leading edge of the hood. The corrosion warranty only goes into effect if the sheetmetal is perforated by rust/corrosion. The dealership that I talked to said that they have alot of complaints about corrosion on the hood, but will not honor it unless the vehicle is under the factory warranty.
Old Apr 6, 2009 | 11:40 PM
mercman86's Avatar
mercman86
Im glad you posted that tsb! I forgot all about that, I had someone print that up for me and I mentioned that to the dealer about the cross contamination. They told me that i was still SOL because it didn't cover corosion on steel body panels, just the aluminum. Go figure...
bkohne1
20
Dec 14, 2010 01:18 AM
kystangbanger
Feb 6, 2010 12:41 PM
Gt-358
May 28, 2005 09:57 PM
Ironman21
Jan 11, 2005 07:59 PM
78blackcherry
40
Mar 5, 2004 01:25 PM
