hood scoops
Old Feb 23, 2004 | 11:15 AM
78blackcherry's Avatar
78blackcherry
Question hood scoops
Does anyone know where I could get a decent looking hood scoop for a 1978 f-150 without having to cut my hood??
Old Feb 23, 2004 | 11:30 AM
Mil1ion's Avatar
Mil1ion
Welcome to FTE!
Actually this question is more aftermarket related than 73-79 specific.
Thread will be moved to either the Aftermarket or the Appearance forum
Old Feb 23, 2004 | 01:10 PM
KJKozak2's Avatar
KJKozak2
Since the purpose of the hood scoop is to scoop air into the carb, what good would it do put one on WITHOUT cutting a hole in the hood?
Are you just going for looks?
K.
Old Feb 23, 2004 | 01:11 PM
Max_'77F250's Avatar
Max_'77F250
I never thought someone that owned a ford truck could be a ricer - until now
Old Feb 23, 2004 | 01:26 PM
73Custom's Avatar
73Custom
No need to call names...
No one would know that it's non-functional until the hood is opened. I've been considering adding a scoop too. I like the look of the 69-70 mustang boss/mach1 scoop. A repo or used scoop can be had for around $75 and it just bolts through the hood - or you can even get the stick-on ones.
I'd prefer mine be non-functional because I drive mine year-round in all kinds of snow sleet and rain, so I'd rather not have to deal with all that pouring in on my engine. Plus I already have a dual snorkle ram air setup installed and would rather keep that.
Anyone have pictures of scoops or custom hoods on a 73-79 Ford? I'd like to see some.
Marty
Old Feb 23, 2004 | 01:36 PM
KJKozak2's Avatar
KJKozak2
I do think they look cool, but I, personally, wouldn't do it just for looks. Unless it had a flip-up top so I could use it as a cooler or for storing my tow strap (I usually have to climb over the hood to hook the strap up anyhow). hehe.
Seriously though, check out US body. They seem to have a lot of stuff like that. Also try ebay.
Kevin K.
Old Feb 23, 2004 | 01:51 PM
CodaSmog's Avatar
CodaSmog
Hey Marty,
Could you do me a favor and post some pics of the dual snorkel set up? I just bought a DS from a 82 stang and I just want to see some set ups before I do something stupid.
Thanks,
Jeff
Old Feb 23, 2004 | 02:01 PM
73Custom's Avatar
73Custom
Sorry, no pics. I used a old Mopar filter housing (holds a larger filter) and put on 2 Ford snorkles. Then I have flex intake tube going to holes on either side of the radiator. Works great.
Marty
Old Feb 23, 2004 | 02:39 PM
CodaSmog's Avatar
CodaSmog
Cool. that's about what I was going to do with the flex but I was looking for a certain kind of fittings for a cleaner look when I attach the hoses next to the radiator.
Jeff
Old Feb 23, 2004 | 02:57 PM
73Custom's Avatar
73Custom
I'm looking for a better option too. I first used wire ties to hold the hose to the rad support. But now my pickup is torn down for body work including a new rad support. So I want to find a better looking option, before I reattach it.
So anyone have any pics of hood scoops on 73-79s?
Marty
Old Feb 23, 2004 | 05:20 PM
hillbillyk's Avatar
hillbillyk
look in my gallery, in the 78 f-150 4x4, it's an old mustang scoop, and there is a hole cut under it to make it functional, they look real good also.
Old Feb 23, 2004 | 06:08 PM
F1rocco-NY's Avatar
F1rocco-NY
Currently non functional while my 460 is in the shop being built.People move out of your way even quicker.
Old Feb 23, 2004 | 07:27 PM
73Custom's Avatar
73Custom
Thanks guys. They look good, gives it some attitude...
Hillbillyk, your mustang scoop is what I've been considering. did you install it? Does the back of the scoop match the contour of the hood? Does it have a special air box to collect the air from the scoop into the carb?
Marty
Old Feb 23, 2004 | 08:23 PM
hillbillyk's Avatar
hillbillyk
it was on the truck when I got it, it has a line right down the middle of the top that matches the one on the hood. You have to file the back a little for the little line down the hood. I have 2 holes cut in the hood, no box or anything, just some fresh air under the hood. We put one on a friends truck without cutting a hole, very easy to install.
Old Feb 23, 2004 | 09:17 PM
F1rocco-NY's Avatar
F1rocco-NY
I got mine off of ebay for like $50 shipped.It matched the contour except in the front it was a little high a rubber mallet and five minutes later I drilled and used a 360 degree pivot style rivet gun.The $25 rivet gun made the difference.Total time 45 minutes.I didnt cut the hood yet because of winter we had 61 inches alone just in January.Plus I have two more hoods for differnt looks for different moods.
