Headlight advice?
Old Apr 12, 2009 | 08:15 AM
  #31
megawatt00's Avatar
megawatt00
Thanks it is easy for me to figure it out but I'm just being lazy.....lol.
Old Apr 12, 2009 | 08:52 AM
  #32
hgoody77's Avatar
hgoody77
so i guess do you use two diodes per light? one inline of the lowbeam wire and one going from highbeam wire to lowbeam wire? like this, for each light?
Old Apr 12, 2009 | 02:27 PM
  #33
SkySkiJason's Avatar
SkySkiJason
Only one diode is necessary with relay harness - between hi and lo beam on factory wiring. (no need for the 2nd diode in your diagram). Without a relay set-up, it may not be a bad idea to put one on each side so the juice doesn't have so far to travel. Since you would be routing 12v thru the puny stock wiring from one side all the way to 2nd headlight.
Once upon a time, I almost added the diode to wiring harness on steering column and put the hi & lo together feature on a switch...
Since I don't really like the 'extra' stock headlite plug just hanging out unpluuged, I think I will get a plug for it and put the diode on the plug..
Old Apr 12, 2009 | 03:31 PM
  #34
King0581's Avatar
King0581
I'll still have to study on this awhile, but I think I can figure it out.
Old Apr 12, 2009 | 04:38 PM
  #35
JockD's Avatar
JockD
I repeat my earlier suggestion to add a second low-beam relay and have separate fuses and relays for each low-beam light. If you have a short in one circuit or lose a relay, you will have one low-beam headlight to get home with.
Back when I drove a Model A for everyday use, I had so many headlight bulbs burn out and leave me without any headlights that I always carried at least 4 spare headlight bulbs at all times. It gets your attention when you lose all headlights at once on a pitch-dark night.
Old Apr 12, 2009 | 08:24 PM
  #36
302F250's Avatar
302F250
I got mine off ebay.I love them really made my truck like a whole lot better.I couldnt stand the stockers.Here's a pic of my truck to get ya a idea
Old Apr 12, 2009 | 09:47 PM
  #37
SkySkiJason
Originally Posted by tojoski
Sounds straight-forward, what size diode is needed?
radio smack 7004 - stripe goes on hi-beam side. I think???? Man, I swear Use it or Lose it!!
I missed this post earlier!!
Old Apr 12, 2009 | 10:22 PM
  #38
hgoody77's Avatar
hgoody77
think of the stripe as a one way valve, it will flow in the direction of the arrow point but won't flow againts the wall/ the opposite way.
High Intentions
Oct 17, 2012 02:30 PM
tjbeggs
22
Jun 3, 2010 12:02 PM
lee_2000_eb_owner
24
Dec 30, 2008 01:55 PM
heavytruk
Jul 13, 2008 08:03 AM
