I dont have them but after looking at the auction... if you are looking to get a HID kit, this is the only thing i would be worried about... "(Modification May Require For Using HID Lighting System)." that is listed right in the auction
I put these same lights on my friends F150 and they are really nice. The houseing was just as good if not better than stock. Halo & LED markers were easy to install. They put out a much better light than the stock ones as well.
I will say installing them us a PINA. They are too big to mount from the front through the grill. But the edge mounting tab on the grill is in the way to fit over the new lights. I ended up using a dremel and cutting those off so it would fit. I first tried this with an old grill I had. I found that it was securly fasened without the tabs.
These came with no instructions.
J
Reason: My IPhone loves the change words
J
Thanx for the info. Any chance you have a picture of them installed. I do have to admit they look pretty badass
I didnt take any pictures of them because it wasnt my truck. I will be buying these after the holidays. They are the same but come with a full HID conversion.
Why are those lights so much more expensive than the others that look identical
Originally Posted by Big-99-expo
good question, they look the same to me.
I don't know, but I trust them a heck of a lot more than I do most of the goons on eBay. If LMC says it will fit.....then it will fit. If they say it is plug & play.....then its plug & play without modification.
