Complex overheating/overcooling problem...need knowledgeable help...I'VE HAD IT
Old Apr 7, 2009 | 10:03 PM
1966Tbird's Avatar
1966Tbird
i would replace the heater core or run a nipple between your heater hoses to bypass the heater core and see how it works then, i think that's your problem it's really tough to get all the crap out of it if there is crap in it
and i know this might not pertain to you but i worked on a mustang witha 347 stroker motor and yates (sp?) heads that would suck the bottom radiator hose shut at around 8,000 rpms and it even had a spring in it we replaced it with exhaust pipe that we cut and welded to the right dimentions no problem since as far as i know, the car would overheat after running the 1/4 and overheat bad
Old Apr 8, 2009 | 05:59 AM
jr32560's Avatar
jr32560
yup and subford said also -check the hoses-they can collapse-will drive ya nuts!the pump pulls the water out of the bottom of rad. and if the hose collapses no water
Old Apr 8, 2009 | 03:48 PM
EPNCSU2006's Avatar
EPNCSU2006
Since the cooling system is a closed loop, is it possible for the lower radiator hose be sucked closed without either a leak in the system on the outlet side of the pump, or a severely clogged radiator?
Old Apr 8, 2009 | 03:58 PM
subford's Avatar
subford
I do not see why not at high RPM coming home empty like he was.
Old Apr 8, 2009 | 09:16 PM
EPNCSU2006's Avatar
EPNCSU2006
Right, so if there's a leak, the lower radiator hose wouldn't be the problem. Or am I not thinking of this the right way?
Old Apr 8, 2009 | 09:45 PM
subford's Avatar
subford
I do not understand what a leak would have to do with it.
The water pump takes suction on the bottom and as long as there is any water in the radiator there is resistance to the flow of the water going down through the radiator. It would not make any difference if the cap is on or off closed system or not. At higher RPM the bottom hose can block this flow if there is not a spring inside the hose or a spring made into the Hose. Maybe not a new hose but when it gets hot and flexible (older) it will.
The big three auto Co. have been putting these springs in the bottom hose starting in at least the 1940s.
Old Apr 8, 2009 | 10:35 PM
Opossum's Avatar
Opossum
The radiator cap being off or not working, or a leak would matter because the system would not build any pressure. This pressure will help keep the hose open.
Old Apr 9, 2009 | 07:49 AM
subford's Avatar
subford
The key word here is HELP but that is not enough sometimes if the radiator resistance is high enough.
carlgrover
1997 - 2003 F150
15
Feb 17, 2017 10:39 AM
tweak1029
Mar 28, 2016 02:27 PM
tabijan
Dec 19, 2015 09:00 PM
Darrell Thompson
Jan 22, 2015 05:28 PM
Deuce40s
Nov 23, 2014 04:22 PM
