Pulled some codes..AE
Old Apr 5, 2009 | 08:32 PM
O2BNMUDD's Avatar
O2BNMUDD
I PULLED SOME CODES THIS IS WHAT i CAME OUT WITH. I think some are just genaric codes but not sure..
1352 ignition key circuitfail..
1359 ignition run acc cir fail
c31000
P0093 Fuel system leak detected-large leak???????? any idea what this is about??
not sure if I need to worry about any of them
Under enhanced powertrain
po0470 exhaust preasure sensor???
0478 exhaust preasue control valve???
Truck was not running ..
Old Apr 5, 2009 | 08:34 PM
F350-6's Avatar
F350-6
Clear the codes and check again next time you take a trip. Sometimes false codes show up. If the EBP codes come back again you can try cleaning the sensor and tube. They're known to pack full of soot.
