Pulled some codes..AE
I PULLED SOME CODES THIS IS WHAT i CAME OUT WITH. I think some are just genaric codes but not sure..
1352 ignition key circuitfail.. 1359 ignition run acc cir fail c31000 P0093 Fuel system leak detected-large leak???????? any idea what this is about?? not sure if I need to worry about any of them Under enhanced powertrain po0470 exhaust preasure sensor??? 0478 exhaust preasue control valve??? Truck was not running .. |
Clear the codes and check again next time you take a trip. Sometimes false codes show up. If the EBP codes come back again you can try cleaning the sensor and tube. They're known to pack full of soot.
