2000 f250 help...rough idle hard to start
Old 04-05-2009, 06:26 PM
saltaholic
saltaholic is offline
saltaholic is starting off with a positive reputation.
Hey guys, I have a f250 7.3l powerstroke with 220,000 miles that takes forever to crank and when it finaly does it lopes really bad at idle. I replaced the glow plugs and checked the relay. After it runs for a while and warms up it runs ok but still sounds awful at idle. What could be the problem?
Thanks
Old 04-05-2009, 06:43 PM
87 F-150 I6's Avatar
87 F-150 I6
87 F-150 I6 is offline
87 F-150 I6 has a good reputation on FTE.87 F-150 I6 has a good reputation on FTE.
How cold is it and what kind of oil are you using? Will it smoke once it starts, how new are the batteries and when did you charge them with a battery charger.
Old 04-05-2009, 06:51 PM
saltaholic
Not cold at all, 60 degrees, does smoke allot and the batteries are brand new.using chevron oil
Old 04-05-2009, 08:16 PM
F350-6's Avatar
F350-6
F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Welcome to FTE. How long have you had the truck, and how often has the oil been changed? What color is the smoke you're seeing? How many miles are on this oil change?
Old 04-05-2009, 10:15 PM
87 F-150 I6
Do you recall what wight of oil your using, and it my be a dumb question but is that synthetic or regular. Depending on how old the oil is and if it is cold, you might want to change it out for some 5-40 Rotella T. Good synthetic oil will start easier and wont make the truck romp when its cold. This might be your problem and Ford says it's ok to run it year round.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
