injector install
Old Apr 5, 2009 | 08:23 PM
fuelman's Avatar
fuelman
injector install
Hey guys
Been awhile... I'm looking for a thread or maybe it was a pdf file that described in detail an injector replacement.If anyone has what i'm looking for please email to me joseph.hulsey@yahoo.com . I'm getting ready to rebuild my AAs into stage1s next weekend.Thanks in advance..
Old Apr 6, 2009 | 11:28 AM
plowhand's Avatar
plowhand
Playing in the Dirt
Go here: Swamp's Diesel Performance look under "Tech Database" in "How To's & FAQ" then in "Injector Removal". Nice in depth write up.
Beans also has a write up here: Beans Diesel Performance
Old Apr 6, 2009 | 08:54 PM
fuelman's Avatar
fuelman
Thanks plowhand i knewsomeone would lead me in the right direction.
Old Jan 23, 2010 | 11:16 AM
jchosler's Avatar
jchosler
Is there a link to replacing the injectors. I'm about to pull them out for the fist time and would feel better seeing a thread about it first.
Old Jan 23, 2010 | 12:05 PM
Talyn's Avatar
Talyn
Best thing to have is a dead blow hammer and a prybar.
take the VC's off, and you take off one of the bolts for the hold downs. I cant remember which one it is.
Slide the deal up and over and pry up with the prybar.
They will pop right out.
use a vacuum pump to get the oil outa the cylinders to prevent hydrolock.
Lube the injectors really good with oil before reinstall. Dont awnt the o-rings to catch when you slide them in. When they are in. use the dead blow hammer to tap them in till they make a distinct ping type sound (turn off the radio is really subtle)
Once you hear that, torque the bolt back in to 10 or 12 ft lbs, (cna't remember)
All the info is in my injector thread somewhere around here.
But thats the run down
Get some new zd-11 glow plugs to throw in if your gonna have everything apart.
Talyn's Avatar
Talyn
Old Jan 23, 2010 | 02:07 PM
RRranch's Avatar
RRranch
Don't forget to take off those little aluminum oil spouts first. They break real easy pulling injectors with them on.
I have always used a 12 inch long wedge bar to get the injectors out. It works great. I have that special Ford tool but only used it once. The wedge is easier and quicker.
Old Jan 23, 2010 | 02:54 PM
Talyn's Avatar
Talyn
yea. dont forget those. haha. they are in the way.
I bought prybars for it, was best money i've spent in a while.
Old Jan 23, 2010 | 07:08 PM
jchosler's Avatar
jchosler
Are Motorcraft ZD-11 good glow plugs that won't swell later on?
Old Jan 23, 2010 | 07:20 PM
427 fordman's Avatar
427 fordman
Yes they are. I just pulled out a set and put new ones in and they all pulled out with my fingers.
Old Jan 23, 2010 | 11:04 PM
funzjb1's Avatar
funzjb1
I just put new o-rings on a couple weeks ago and mine was a mother f@#$ to get out. I had to start to twist them sideways then pry on them ( prying on it first I almost bent the prybar). each one was like it was glued in.
Hitting it with the dead blow is good but I could not always get a good swing with it, had to hit it with the handle of the dead blow.
Old Jan 24, 2010 | 06:31 PM
jchosler's Avatar
jchosler
how did you get the fluid out of the injector cylinders. I'll probably use a syringe
Old Jan 24, 2010 | 06:50 PM
427 fordman
Pull the rears out first and most of the oil will go back to them holes. Clean them all out though. I just used a plastic syringe with a 1/4" plastic clear hose. Worked good. Just make sure you get it all. I did the back one on the pass. side like 6 times cause I kept getting more out.
Old Jan 24, 2010 | 09:58 PM
jchosler's Avatar
jchosler
ok. I had a heard time getting the injectors out also. I slipped with the pry bar and broke part of the casing to the solenoid on top of the injector . I was pist. I'm sending the injectors off to rosewood to be upgraded to stage II's so hopefully they'll have a solution.
Old Jan 25, 2010 | 06:04 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
No problem Jacob, I have a few extras.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
