Bronco II Ford Bronco II
Hub Conversion
Old Apr 4, 2009 | 11:23 PM
stimmie78's Avatar
stimmie78
Hub Conversion
If I purchase a warn/superwinch/mile marker auto to manual hub conversion kit, will any hubs work? or would it have to be the same brand as the kit?
Old Apr 5, 2009 | 12:15 AM
mrshorty's Avatar
mrshorty
I can't say for 100% sure on the superwinch, but I know the milemarker/Warn kits are the same (because I have one Warn and one milemarker hub). As the design for manual hubs is pretty standard, I fully expect the superwinch are the same as the other two, as well.
Old Apr 5, 2009 | 04:22 AM
kernel-panic's Avatar
kernel-panic
I think all the OEM/aftermarket outer shafts have the same spline count, but don't quote me on that - I have seen some that use a different spline count than the OEM equipment on some models.
Old Apr 5, 2009 | 10:05 AM
stimmie78's Avatar
stimmie78
so I could find the cheapest conversion kit, then get the hubs I want..
thanks.
Old Apr 5, 2009 | 10:09 PM
F100classics's Avatar
F100classics
My 90 Bronco II had the same number of splines as an Explorer. Therefore, I used OEM manual locking hubs from an Explorer that I found at a wrecking yard. Not all Bronco II's would be candidates for this interchange. I believe earlier years used less splines, so the model year is important to the conversion kits' application.
Old Apr 5, 2009 | 10:57 PM
stimmie78's Avatar
stimmie78
It's an 86 so that would be a no go ... what about stock parts off of a junker of the same year? Would I be able to get what I need then?
Old Apr 6, 2009 | 02:07 AM
kernel-panic
Yes. If you're taking parts from a manual hub Dana 28 TTB ('84-'89 BII, '83-'89 Ranger; with some exception(s): some '89s/'90s had the Dana 35 and some had Dana 28 guts in the 35 housing, so in that case you would have to check spline counts, IIRC), then you should be okay. You'll need the hubs, locknuts and the spacer between them. I can't remember if the spindles are the same or not or if the outer shafts are the same or not, but be prepared to get all of that stuff as well.
Old Apr 11, 2009 | 10:31 PM
97Centurion's Avatar
97Centurion
Rub my Belly
Any manual conversion kit will work with any other manual hub as long as both are for your D-28. Someone once told me that you can get the parts from ford cheaper than you can get a conversion get. Not sure if that's true or not.
Old Apr 12, 2009 | 12:37 AM
bigswede's Avatar
bigswede
Tony! Where you been?
Old Apr 12, 2009 | 03:35 PM
97Centurion
Rub my Belly
Here, There and Everywhere! lol Seems I haven't have had time for the fun stuff lately. I still lurk quite abit though.
Old Apr 12, 2009 | 09:36 PM
stimmie78's Avatar
stimmie78
So does anyone have part numbers for the spindle nut and lock washer? The local Ford dealer parts dept leaves much to be desired and I'd rather go in and ask for the part by the number..
Old Apr 13, 2009 | 07:06 AM
kernel-panic
IIRC, most local auto parts carry those?
Old Apr 13, 2009 | 06:07 PM
97Centurion
Rub my Belly
I'm sorry, I meant a parts store instead of Ford. My friend said he got his D-35 Spindle nuts from NAPA. I would assume they could get the D-28 stuff also.
Old Apr 14, 2009 | 05:04 AM
kernel-panic
Should be able to. I believe Napa, AutoZone, Shuck's/Kragen/etc, and O'Reilly all list 'em.
mudslinging79
1978 - 1996 Big Bronco
May 6, 2014 09:33 PM
79 bronc
May 25, 2011 06:32 PM
stuckinthesnow
Apr 15, 2004 11:15 AM
wfodickinson
13
Jan 19, 2004 09:04 PM
