Sponsored by: Real Truck
Black tailpipe?
Old Apr 4, 2009 | 04:03 PM
Neil_E.'s Avatar
Neil_E.
Black tailpipe?
No I don't mean the outside. I've got about 1600km (1000mi) on it and the inside of the tailpipe is lightly coated with a black deposit. Looks pretty much like a diesel tailpipe.
The mileage works out to 15 per imperial gallon (this would be 12 per US gallon). Considering that I run no load other than me, the mileage isn't great. I find the 5.4 power is totally adequate for my needs; I have yet to exceed 3,000 RPM. My driving is a 70/30 split highway/city. I set the cruise at an indicated 110 kph (68 mph) with the tach reading 2000 RPM.
I'd have the dealer look at it, but the service engine light would need to be on before they would investigate. The only drivability issue is the annoying idle hang, but the FI is designed to operate that way.
Using 87 grade as per the owners manual. Trying different brands of gas hasn't made any difference so far. My normal drive takes about 25 minutes back and forth to work.
Old Apr 4, 2009 | 04:19 PM
bubbasz1's Avatar
bubbasz1
Sounds pretty normal to me, mileage and all.
Old Apr 4, 2009 | 05:44 PM
senix's Avatar
senix
yup...that is about it. heavy truck isn't going to do real great on mileage.
Old Apr 4, 2009 | 05:58 PM
Neil_E.'s Avatar
Neil_E.
I'm more concerned about the filthy tailpipe. I thought these modern vehicles were supposed to have clean tailpipe emissions.
Old Apr 4, 2009 | 06:07 PM
sncblue03's Avatar
sncblue03
Nope. You're burning a hydrocarbon. It's gonna leave some black junk.
Old Apr 4, 2009 | 09:05 PM
WeWonIt's Avatar
WeWonIt
Yep, Mine had black build up when I cut it up. Even my Fusion has some after 20,000miles, and I believe it's supposed to be a "partial zero emissions vehicle" what ever that means.
Old Apr 4, 2009 | 10:08 PM
aldridgec's Avatar
aldridgec
It means when it is not running it has zero emissions. Meaning there are no evaporative emissions from the fuel system leaking into the atmosphere.
Old Apr 4, 2009 | 10:51 PM
WeWonIt's Avatar
WeWonIt
Really? that seems kind of missleading. Oh, well I tried to be nice to the tree huggers. I guess it's time to start cutting on that exhaust too.
Old Apr 4, 2009 | 11:38 PM
redford's Avatar
redford
FTE Leadership Emeritus
My '07 5.4L has the same black coating on the inside of the tailpipe. I always attributed it to the factory PCM settings, which will start out a little rich (by default) until the PCM learns your driving habits and adjusts the fuel/timing map accordingly.
A little rich and a little less timing is far safer than a little lean and a little too much timing.
Old Apr 5, 2009 | 10:08 AM
dkf's Avatar
dkf
Sounds like the OP truck is normal to me. Some blackish soot inside the pipe is perfectly normal. A CC is a heavy truck, your not doing the engine any favors by lugging it. Don't be afraid to go over 3k rpm even 4k rpm.
The minut fuel and timing changes of the stock tune will not affect the soot coming out the tailpipe. My truck is tuned to run around 12:1 A/F ratio at WOT for max power with an aftermarket converter and the soot is pretty much identical as stock tuning with the stock converter. Stock tuning runs stoich all the time under normal conditions.
