Help!!
Old Apr 3, 2009 | 09:55 PM
chandler213's Avatar
chandler213
Help!!
ok i know this isnt a ford but if anyone can help id love it....
I have a 85 Ram 250 with the 318...she wont start up...
It sounded like it wasnt getting a spark so i threw a new ignition coil on her, and...nothing
got a new coil wire....nothing
so i took a look at the plugs they were completely shot...i grabbed some new plugs and threw em on....sound like she wanted to go but....nothing
i took the distributor cap off, looked ok....
it almost sounds like its not getting fuel but ive poured gas in the carb and she still wont go, not even with start fluid...
my next guess is ignition module?
any help would be great...she is currently parked in a buddy's driveway and his parents don't think she is too pretty lol...
Old Apr 3, 2009 | 10:02 PM
bleach1012's Avatar
bleach1012
take your fuel line off somewhere after the fuel pump and see if its pumping.....or you might be able to see through the fuel filter if its clear....
Old Apr 3, 2009 | 10:03 PM
chandler213
any idea where the fuel pum is on these bad boys?...in the tank or on the line?
Old Apr 3, 2009 | 10:07 PM
bleach1012's Avatar
bleach1012
hmm...dont know, if its mechanical it well be on either side of the block at the front of the motor..google it i guess. you haven't screwed with timing have you?
Old Apr 3, 2009 | 10:08 PM
chandler213
no havent touched the timming... i dont think its a fuel prob.,...i mean it would have started up since i poured gas in the carb...
Old Apr 3, 2009 | 10:11 PM
chandler213
maybe a carb prob...the carb does look pretty ghetto rigged on there
Old Apr 3, 2009 | 10:15 PM
bleach1012's Avatar
bleach1012
no idea man, hard to diagnose w/out being there...did you pour the gas in while trying to crank it?
Old Apr 3, 2009 | 10:16 PM
1 F150dude's Avatar
1 F150dude
It is probably the ignition module. They are notorious for suddenly going out. I have had about 15 Mopar vehicles in the past, so i am speaking from experience. Look for signs of the wax coating melting off the back of the module. Thoroughly clean the mounting surface of melted wax before installing the new module.
Old Apr 3, 2009 | 10:20 PM
chandler213
thanks alot man...i planned on picking one up in the morning...ill post back on here and tell you what happens...i was working on that truck for about 5 hours in his driveway while he wasnt even home today lol...2moro ill be taking a lot more tools lol...well cross your fingers ill let you now how it goes
Old Apr 3, 2009 | 10:22 PM
1 F150dude's Avatar
1 F150dude
Yeah those little buggers have made me pull lots of hair out, cuss, kick, and throw tools.
Old Apr 3, 2009 | 10:24 PM
bleach1012's Avatar
bleach1012
yeah, ignition module does sound more likely....step by step
Old Apr 4, 2009 | 12:27 AM
Dean88's Avatar
Dean88
Do you have any spark at all?? As in when, I figured you would have tested when you changed the plugs.
Old Apr 4, 2009 | 01:46 AM
Sycostang67's Avatar
Sycostang67
If you swap the module and it still doesn't start, you might want to try a new cap/rotor anyway. I had an 80 Dodge with the 318 that would occasionally not start. Everything looked good. I pulled a plug and checked for spark and I saw a spark so assumed it was good. After 2 days of fiddling with it I bought an in-line spark checker. I had an occasional spark, sometimes it was there and then it would just disappear. I put a new cap and rotor on and never had another problem after that.
Old Apr 4, 2009 | 09:59 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Did you check for spark??
-Enjoy
fh : )_~
Old Apr 5, 2009 | 06:48 AM
chandler213
Yes i checked for spark...om getting spark through the coil but dont know how far past that...ive changed the ballast resistor, some radio frequency thing, and tried a bunch of stuff...im thining it is either
1# Fuse ( these trucks dont have normal ones they are like wire fuse's and hard to find)
2# rotor button/ distributor...
3# some spark controler or something like that(my good friend at the part store said can only get at dealership for around 400$)
if it is the last one i wont be fixing it lol...ill be selling it to my friend at the part store for a decent price of around 200$
