Bronco II Ford Bronco II
High Output Alternator
Old Apr 2, 2009 | 07:14 PM
89_Brnko2!!'s Avatar
89_Brnko2!!
Ok guys ive got a 90 bronco 2 that i will be adding a set of dual driving lights,as well as a sound system,and a few other electrical things....problem is noone makes a higher output alt. for these things,and i need more than 80 amps!!! i work at an advance auto and was looking at an alt. for a 90 mustang gt and other than the mounting ear being in a different spot all the plugs and everything are the same.....so heres my idea,buy a high output alt for a 90 mustang and swap out the front part of the case so it will bolt up to my truck,the bolt holes on the case and everything are identical!! the only difference in the alternators is the angle of the mouting ear...enclosed is a pic...tell me what yall think!!!!
<img src=http://c2.ac-images.myspacecdn.com/images02/78/l_a8083c57bc64432088fb81e025fe8ec9.jpg>
Old Apr 2, 2009 | 07:15 PM
89_Brnko2!!
Bronco 2 on the right...mustand on the left
Old Apr 3, 2009 | 03:09 AM
kernel-panic's Avatar
kernel-panic
Who doesn't sell a higher-output alternator for the 2.9? I could have sworn I saw some on Summit. Anyhow, that should work. I think I recall seeing where someone used the 'stang alternator as is and made it work. Let us know how it turns out
Old Apr 3, 2009 | 03:45 PM
BII Plow Truck's Avatar
BII Plow Truck
I bought a new 160 amp unit for my BII to power the snowplow and extra lights, etc....picked it up on eBay cheap.....you have to run a 4 ga battery cable direct to the battery......runs cool compared to the stock unit, and powers everything turned on at once!
Why 160 amp? I looked up brand new F250/F350 Super Dutys with the plow option and they come with a 140 amp unit.
optikal illushun
49
Jul 25, 2023 11:20 AM
Smirks90
Nov 3, 2014 09:58 PM
Dave R.
Electrical Systems/Wiring
Sep 14, 2012 11:04 PM
sdetweil
Jun 13, 2008 09:10 PM
pen_field
Mar 17, 2007 09:06 PM
