Leaf Spring Swap
Old Apr 2, 2009 | 06:00 PM
qixer01's Avatar
qixer01
Leaf Spring Swap
i have a 1979 f-150. my springs are weak. i tried to put sum springs out of a 78 f-350 but they were too small. what year and model will be the same size and bolt right up?
Old Apr 2, 2009 | 07:27 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Was the 78 a dually? Springs from a 78-96 150/250/350 srw are the same. 3" wide by...uhh forget the length
Old Apr 2, 2009 | 09:32 PM
armstrongfordtrucks's Avatar
armstrongfordtrucks
F-350 rear springs are the same as the high boy. They are only 2 1/2 inches wide. They are 1973 thru 1977.5 high boy 1973 thru 1996 F-350 4X2 are the same. If you want 3" springs I believe you will be looking at 73 thru 79 1/2 and 3/4 ton 4X2 and 1977.5 thru 1979 F-250 and F-350 4X4.
Good luck
renegade_75
Mar 13, 2013 02:50 PM
seankim
Apr 11, 2012 10:24 AM
fgials
Oct 13, 2010 03:08 PM
StrokiN&SmokiN
Aug 11, 2008 11:52 AM
88bronco351
Offroad & 4x4
Jun 29, 2006 08:40 PM
