When to stain
Old Apr 2, 2009 | 12:41 PM
ford2go's Avatar
ford2go
When to stain
Hi,
I'm getting a screen porch put in to replace my old deck. It will have cedar flooring and rough cedar siding.
Last time I built a deck, I was advised to wait a couple of weeks before staining. I did that, but I'm not sure that it was a good idea.
I'd appreciate any input on this.
Thanks,
Old Apr 2, 2009 | 01:39 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
It all depends on how dry the lumber is. Kiln dried lumber should be able to take stain immediately.
I built a deck out of douglas fir and it was air dried. Actually not so dry at all, it was pretty wet. You could feel the difference in weight between the wet lumber and similar sized dry lumber. I tried an oil based stain on a small spot and the stain literally floated on the lumber. It would not soak in because the lumber was so wet.
I don't remember exactly how long I waited, but it was probably at leat 6 weeks of dry sunny weather. Then the stain soaked right in.
Most of the thinner cedar I have seen was dry. Stuff like 1x6 or 1x10. I think they kiln dry the thinner stuff to keep it from warping. I dunno for sure, I'm not an expert on wood. But I'm guessing if your deck is built from 2x6 or 2x8 it is probably air dried and may still be pretty wet.
Old Apr 2, 2009 | 02:31 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
A lot depends on the type of stain you intend to use as well.
Depending on where you live your floor (2x, 5/4", ..???) may be S Grn (surfaced green= more than 19% MC)
If so, give it some time to dry out.
Be sure to use a stain meant for walking surfaces.
As for the siding, is it Channel, Bevel, board and batten?
Most often these will be kiln dried and you should stain them immediately, before they have a chance to soak up water.
ford2go
Aug 29, 2013 06:38 AM
Furyus1
29
Sep 27, 2012 11:21 PM
CowboyBilly9Mile
Oct 25, 2005 12:29 PM
jdmorg
Apr 24, 2005 07:50 PM
jskufan
Jun 8, 2004 12:53 PM
