does anyone know what this is?
Old Apr 2, 2009 | 07:22 AM
tlolesen's Avatar
tlolesen
This is my 75 F-100 with a 360, it is on the fire wall right in the middle. There is one black wire going in the cab and one going with the rest of the wires in engine compartment, there was a single vacume line to it that I removed because I think the part is cracked. I assume it is some sort of switch but do I need it? It does not seem to effect anything.Thanks and I hope the picture comes through, I believe I finally figured it out.
Old Apr 2, 2009 | 10:32 AM
justforkicks's Avatar
justforkicks
if you know what color the wire is, then follow it. it looks like some kind of vacuum solenoid switch, but ive never seen anything like it before. i have a 77 f150 and it doesnt have that
Old Apr 2, 2009 | 11:29 AM
fmc400's Avatar
fmc400
MSEE
If it had a single vacuum line going to it, my guess would be an economy light switch. Some trucks had a light on the dash that lit up when vacuum dropped past a threshold, to warn you that you're getting sub-obtimal fuel mileage. That'd be my guess. I've never actually seen one (they are rare) so I can't tell from looking at it if it's the factory type or not.
Old Apr 2, 2009 | 02:13 PM
Jermafenser's Avatar
Jermafenser
That may be the infamous idiot light for "LOW FUEL ECONOMY". Since yours is a 1975, it's a possibility. Does it have any stamps/logos etc on it?
Here's a pic of the light from a junked '75.
Old Apr 2, 2009 | 02:38 PM
77red4x4's Avatar
77red4x4
Hmmm. I learned something today. I've never knew that light existed. But I had a 74 and a 77.
Old Apr 2, 2009 | 02:39 PM
Jermafenser
It went on 1975 MY only.
Old Apr 2, 2009 | 02:47 PM
Alvin in AZ's Avatar
Alvin in AZ
Mine had one of those on the firewall for its first year! :)
Doggone it was cool seeing the picture, TL...
...I plumb forgot what it looked like. LOL :)
The bulb was removed in the first 6 months or so? {shrug}
Can't remember how long I put up with it. ;)
The novelty of it wore off pretty dangged quick with it flashing
at me every time I tried to move the truck forward. The sorry
sucker couldn't move itself from a level spot without putting it
in 1st gear (grandma on a T18) or slipping the hell out of the
clutch in 2nd because of the EGR, smog cam and being too
lean in the low speed circuit plus it had idle limiter caps on the
mixture screws too. I soon heard you could pop those off and
shove 'em back on tho, adding a quarter to half turn richer in
the process. ;)
The rebuild with the new 252/252 Comp "Economy" cam did
more for the gas mileage than using electricity to light the light
bulb ever did. ;) ...and a couple other things.
Alvin in AZ
Old Apr 3, 2009 | 06:46 AM
tlolesen's Avatar
tlolesen
Thanks guys, I do have the low fuel economy light and when I replaced all the lights on the instrument cluster I left that one out. I think I will leave it there for good luck and not attach the vacume to it.
Old Apr 3, 2009 | 10:10 AM
lasthighboy's Avatar
lasthighboy
good to know what that is. ive seen them on a couple different trucks and nobody seemed to know. not sure that ive ever seen one with everything hooked up to it in working condition either.
