CT BUY/SELL/TRADE Ads
Chapter Buy/Sell/Trade Ads: Each chapter will have one (1) thread for chapter members to list items wanted, for sale or for trade. The rules for posting in this thread are as follows:
CT Archived Buy/Sell/Trade Ads
- Only Ford truck related items and automotive tools & equipment can be listed.
- Only one picture is allowed per post, per item. If additonal pictures are necessary, place a link in your post to those pictures. Additional posted pictures will be removed without warning.
- You must have your private messaging (PM) turned on and be able to receive PM's to post an ad in the Chapter thread. If you do not, your post will be removed.
- Use the PM or email system to conduct all discussion and transactions regarding the item(s). You can post your interest in the item(s) and that you’ll contact the seller but no discussions. Keep it short.
- If you post an ad, please reply that you found, sold or otherwise disposed of the item.
- The buy/sell/trade thread will be purged periodically for old postings. Generally every 30 to 60 days.
- You need to be an active Chapter Member on FTE to post a wanted, for sale or for trade item(s). No Exceptions.
- You must have permission from the Chapter Leader or a Regional Moderator to post an ad in a chapter that you are not a member of.
- If you are new to FTE (less than 15 days) or have less than 25 posts, you must contact the Chapter Leader for permission before posting an ad.
- Your ad or reply to any ad is subject to editing or deletion at discretion of the Chapter Leader, Moderators or Administrators of FTE.
- Commercial advertisements are strictly prohibited.
Pretty quiet in here but figure its worth posting since I am in CT 06424. I took three brick nose trucks and made one out of them. I have a 1990ish (will confirm if needed) 460/ZF 4x4 truck that's pretty rotten but have been able to scavenge some good parts from it. The engine/trans are still in it in unknown condition but would definitely consider the engine a core. Not sure on the trans at all. Truck #2 was originally a 87 F250 2WD with a 6.9 IDI. I dont have the engine/trans from this one.
List of big items, but really have a lot to offer if anyone wants to swing by and have their way with the trucks/shelves of parts:
-7ish foot flatbed that was installed where a 8ft bed would go (unsure if frame modifications are needed but i believe it may be welded to the frame in a couple spots). Pretty good shape, could use a descale and some paint. LED lights, two of which are flashy orange, two others white reverse lights. Recently made pressure treated stake sides. Gooseneck built in. Must help me remove from truck and need buddies to help lift.
-Planning to keep for future unknown project but would part with the front Dana 60 out of the 460/ZF truck. Ill have to see what the ratio is.
-Planning to keep for future unknown project but would part with the rear sterling 3.55/Limited slip axle from the 2wd f250.
-Set of dark green front fenders. Fairly rust free but dented/dinged in places. I fitted them but didnt care for the color mismatch and the way they fit due to some of the damage on them. Id just really hate to toss them if someone can use them.
-Set of blue/white front fenders with rust on the arches. Other than the rust, they are really straight.
-Decent blue hood with some rust at the leading edge (matches the above blue/white fenders)
-Decent dark blue hood with a little rust but its straight as well. Might have an OK fender that will match this hood. I believe its the drivers.
-Hood hinges and lift springs
-various interior trimmings for both a brown (XLT lariat) and a blue (custom) interior.
-pedal cluster with clutch, arm already modified to accept the clutch heim mod
-manual steering column
-Headlights, no buckets. Clouded and could use a buff.
-no bumpers
-no good rad supports
-no good fuel tanks
I will be shelving a lot of the smaller easier stored and potentially useful stuff, but most of the bigger items will be going to the scrapper in a month or two. Please PM me with interest.
UPDATE: I am acquiring a '90ish F250 4x4 in a week or so to grab some parts i need from. It is a 351/auto truck. I will be using the transfer case and the rear driveshaft at a minimum. It will be kept as a roller with the bed and cab complete enough to be used as storage. Otherwise its fair game. This one will be staying at a friends house, so it will be around for quite some time. List above not updated with items from this truck as i do not have it yet.
-no bumpers
-no good fuel tanks
@Towmanjbo (Justin), Did you still want that rear Bronco window? The tailgate got the dumpster treatment a few weeks ago but I remembered you had said you might be able to make use of the glass.
ill be in touch.
Hello neighbors! Sadly, I had to sell my truck. I removed a bunch of stuff from it, and am willing to hookup my FTE buddies! Let me know if you are interested in anything, I am sure we can cut a deal.
Hammerhead running boards for regular cab https://www.ford-trucks.com/forums/market/1689192
Tonno Pro hardfolding 8' bed cover https://www.ford-trucks.com/forums/market/1689193
Nokian winter tires on steelies https://www.ford-trucks.com/forums/market/1689194
Weathertech floor mat/ Bed cleats / Bed mat / LED lightbar https://www.ford-trucks.com/forums/market/1689195
F150 cupholder mod https://www.ford-trucks.com/forums/market/1689196
Complete Western plow setup https://www.ford-trucks.com/forums/market/1689197
I also have misc parts (oil filters, Naviks audio adapter, Gill expedition center headrest tray and bracket, 2.5" tow hitch D ring etc.
Thanks for looking!
Thanks for looking!
Huge CM Flatbed for sale
S O L D .....................
This flatbed is BIG!! - In Bonney Lake Washington
For sale is my CM Flat Bed in great condition, new these go for $6k plus....
I am only selling due to going with another setup on the back of the truck.
It is currently on a 2017 F550 cab chassis that is 84" cab to axle and 203" wheelbase.
It has LED stop/turn/marker lights.
It is set up for gooseneck or bumper towing.
ASKING: $4,400. or best offer, it's off my truck sitting on stands, all you have to do is back underneath it and I'll lower it down on your truck, then off you go.
SEND ME A PRIVATE MESSAGE IF INTERESTED...... Price negotiable....
Here is the Manufacturer Information form their website:
LENGTH: 11'4"
HEADACHE RACK: Steel Tube
DECK: 1/8" Treadplate
FRAME RAILS: 4" Structural Channel Steel
CROSSMEMBERS: 3" x 3/16" Channel
REAR SKIRT: Solid One Piece with Tapered Corners
GN HITCH: 30K B&W Hitch with Welded Ball
BP HITCH: 24K B&W 2 1/2" receiver hitch with receiver tube
FUEL FILL: Angled
12V TRAILER PLUG: 12V Round 7 Pin in GN Box, Round 7 Pin/4 Way Flat on Rear
REAR LIGHTING: Clear LED Oval
LIGHT BOX (REAR SKIRT): Steel
MARKER LIGHTING: Bullet DOT Approved LED
LENGTH: 11'4"
FUEL FILL: Angled
Received 3,780 Likes
on
@2017 F550 Overlander You should post your add in the Washington buy, sale and trade forum. Currently your add is in the Connecticut section. Trade/Sell/Want/Need your stuff here! - Ford Truck Enthusiasts Forums (ford-trucks.com)
