What solvent to clean differential?
Old Apr 1, 2009 | 11:55 PM
84farmtruck's Avatar
84farmtruck
I pulled the rear diff cover off my 2000 4X4 Expedition 5.4 177,000 miles and the oil flowed out like hot brown fudge. I really want clean the diff out well before the refill. What type of spray should I clean it with, Gunk Spray?? Brake Cleaner spray??? Thanks
Old Apr 2, 2009 | 12:56 AM
flamebuster's Avatar
flamebuster
either one will work. I am a cheapo so I use gasoline and a solvent brush.Good oportunity to put a small magnet in bottom of case before you install cover. Catches metal fines and keeps them from floating around in oil..
Old Apr 2, 2009 | 01:51 AM
alloro's Avatar
alloro
Paint thinner works good and it's fairly cheap. That's what you'll find in many parts washing bins.
Old Apr 2, 2009 | 12:22 PM
howler4x4's Avatar
howler4x4
Please be careful using a flammable cleaner.
Hot brown fudge eh? If the oil is contaminated, check the axle tubes. Your new, clean oil will bring any gunk in the tubes back into R&P and bearings.
Old Apr 2, 2009 | 01:22 PM
84farmtruck
Thanks for the good feedback all. I inspected the oil and while brown there were no metal shavings or other matter.
Any advice on flushing the axle tubes?
My thought was to change the diff oil again in a month or so to remove any left over crud.
Old Apr 2, 2009 | 07:31 PM
flamebuster
I would wait till the hotter weather is here it will flow a lot better, only good way to really clean the axle tubes is to pull the axles. the heaviest of the junk should be in lowest spot which is your pinion pot. Probably seems thicker in the colder weather too.
djed
S. California Chapter
Aug 16, 2012 01:41 AM
fordpride
May 12, 2010 06:52 PM
Iceman_AKA_Ford guy
May 9, 2010 02:06 PM
doug1003
1997 - 2003 F150
Feb 24, 2006 05:46 AM
DeckedoutF150
Paint & Bodywork
Feb 12, 2005 09:25 PM
