PO171 and PO174 codes
Old May 8, 2010 | 01:09 PM
Iceman_AKA_Ford guy's Avatar
Iceman_AKA_Ford guy
I have p0171/p0174 code on 96 f-150 4.9 300. I have replaced the map sensor,egr valve, fuel pressure sensor, and intake gasket, and have sprayed starting fluid to check for vacuum leaks none found. what Im going to do next is spray carb cleaner into the intake to clean any carbon build up because the ford place didn't clean it out
Old May 9, 2010 | 08:49 AM
798hand's Avatar
798hand
I v got that to and can't find it
Old May 9, 2010 | 09:04 AM
Conanski's Avatar
Conanski
Clean MAF sensor and check for leaks in the Thermactor smog system if so equipped.
Old May 9, 2010 | 02:06 PM
Iceman_AKA_Ford guy
Its a new MAF sensor and where do i look to see if i have a smog system. i live in NC.
iamtodd4160
Jun 12, 2016 02:05 PM
big ole ford
Oct 7, 2013 07:01 PM
werefour146
Aerostar
16
Apr 4, 2013 04:14 PM
ggilder
1983 - 2012 Ranger & B-Series
Aug 3, 2011 05:22 PM
Godfrey08
1997 - 2003 F150
Nov 16, 2010 08:08 PM
