Sponsored by: Real Truck
po605
Old Apr 1, 2009 | 07:26 PM
in heat's Avatar
in heat
po605
got my new tuner today and for four hundred dollars all it does is turn the check engine light on trouble code is po605 and the truck onky has 16500 miles on it and withe the canned tunes I cant say it makes a bit of difference no better throttle responce and no better acelleration? these things must do something?
Old Apr 1, 2009 | 07:42 PM
senix's Avatar
senix
get your money back! What kind of tune, what type of motor do you have.
Old Apr 1, 2009 | 07:46 PM
in heat's Avatar
in heat
sct running canned tune no dif at all just a check engine light
Old Apr 1, 2009 | 07:47 PM
in heat's Avatar
in heat
5.4 witha thrush chambered muffler and the air box modded
Old Apr 1, 2009 | 07:48 PM
in heat's Avatar
in heat
can't turn up rev limiter in newtral truck gos better stock in tow haul mode
Old Apr 1, 2009 | 07:49 PM
in heat's Avatar
in heat
I don't have the custom tunes yet but I really don't like cel on in a truck that isnt even a year old yet?
Old Apr 1, 2009 | 09:48 PM
PowerStrokeHD's Avatar
PowerStrokeHD
Not sure if you checked what the P0605 DTC is, but it sure looks to be related to your new tuner...
P0605 - Internal Control Module Read Only Memory (ROM) Error
Description - The powertrain control module (PCM) ROM has been corrupted.
Possible Causes...
- An attempt was made to change the calibration
- Module programming error
- Damaged PCM
- Aftermarket performance products
Old Apr 2, 2009 | 09:52 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Go back to who you bought it from - sounds like it's the wrong tuner.
Old Apr 2, 2009 | 10:30 AM
senix's Avatar
senix
That is what should have been the first thing going. What is wrong with the truck in stock form?
Old Apr 2, 2009 | 11:00 AM
Downriver Thunder's Avatar
Downriver Thunder
I know my 5.4 in stock form was a dog but with the Superchips it really got woke up.
itsunday25
Jul 7, 2011 05:22 PM
smokeydave
May 19, 2011 03:21 PM
88Ford Blue
28
May 27, 2008 08:33 AM
FordGuy_till I die
Feb 7, 2008 07:30 PM
