wing vent
Old Apr 1, 2009 | 06:48 PM
pells49's Avatar
pells49
wing vent
I did a search and couldn't really find what i was lookin for, I need to remove the glass out of one wing vent and install it in another, is there a good way to do this? I was thinking either heat or a solvent of some sort, these are glued right? I would just swap out the whole unit but one post is totally rusted out. what is good for the install? glaziers putty? or some type of glue? I also need to glue some glass into my lift channels, same stuff?
Thanks pells
Old Apr 1, 2009 | 07:11 PM
gearhead1952's Avatar
gearhead1952
The glass is installed with double sided tape available from repro places cheap. Easy way to get the glass out is to leave the assembly mounted on the door and secure the door so it won't open on you. Then open the vent window all the way and grab the end of the glass with both hands and start pulling, rocking it top to bottom.
Old Apr 1, 2009 | 09:39 PM
Woodsman_30350's Avatar
Woodsman_30350
Another option is to hold the glass firmly and rock the truck.
Old Apr 1, 2009 | 09:58 PM
pells49's Avatar
pells49
Thanks, i'll see what happens. Do you use the same doublesided tape to mount your door glass in the channels too?!? dosen't seem strong enough.
If this sounds like a stupid question, bear with me. I'm learnin, and just want to do it right.
Old Apr 1, 2009 | 11:03 PM
gearhead1952
Same tape. I have used it. It doesn't seem like it would hold but it does, makes for a tight press fit in the channel. As long as the channels are clean and smooth there should be no reason to have a tight grip on the glass when the window is rolled down. I don't think the original was sticky just provided a tight fit.
Old Apr 2, 2009 | 08:44 AM
pells49's Avatar
pells49
Cool, thanks gearhead.
Old Apr 2, 2009 | 02:53 PM
low54's Avatar
low54
pells, useing a hammer works too...;P
Old Apr 2, 2009 | 03:45 PM
fking1's Avatar
fking1
Broke mine taking it out. The glass was so adhered to the tape and frame that it would not budge no matter what I did.
Old Apr 2, 2009 | 04:18 PM
pells49's Avatar
pells49
The glass was so adhered to the tape and frame that it would not budge no matter what I did. <!-- / message -->
now that's what i'm talkin about!!!
just tryin not to break it....
Old Apr 2, 2009 | 04:55 PM
david53ford's Avatar
david53ford
hI just did mine used a heat gun on the steel when it got little warm worked it back an fourth and slid right out . going back in was a more difficult. two diff size of tape went to a glass shop and they have a special tool to pull the glass in with. He said he's used gas on the rubber to install them. and it works good.
Old Apr 2, 2009 | 08:15 PM
Julies Cool F1's Avatar
Julies Cool F1
Maybe you could help it a little by running the blade of a utility knife down between the glass and channel first.
Old Apr 2, 2009 | 08:41 PM
LEckart's Avatar
LEckart
I haven't tried it but I was told to take it out of the truck and pour some lacquer thinner around the frame, let it set awhile and it will loosen the tape. By the way what is meant by double-sided tape? You don't mean with an adhesive on both sides do you? The glass setting tape I purchased at the glass shop was just a black tape without any adhesive. It held the glass firmly in place with friction by carefully forcing the glass into the channel. The tape was bent to form a "U", put around the glass edge, then the glass was tapped into position with a rubber mallet.
Old Apr 3, 2009 | 11:43 AM
abe's Avatar
abe
Unless you need to have the FoMoCo label on the glass, why not just get a glass shop to cut you a new piece and have them put it in?
Old Apr 3, 2009 | 11:53 AM
53rat's Avatar
53rat
I heard soaking them in gas works wonders.
Old Apr 3, 2009 | 12:00 PM
gearhead1952
You may be right about the sticky part, now I don't remember if it was or not. In my mind it was at least on one side. I don't have any left to go and check.
