Sponsored by: Real Truck
CD player problem
Old Apr 1, 2009 | 12:28 PM
darthracer777's Avatar
darthracer777
Exclamation CD player problem
I have the single disc CD palyer in my F-350. It won't eject the CD. When I press the eject button, I get the error message 'err'.
Is there anyway to remove the CD without removing the face plate?
Old Apr 1, 2009 | 01:57 PM
mnpowerstroke99duty's Avatar
mnpowerstroke99duty
I had a similiar problem with my 6 disc cd player.I pulled the unit out of the dash and removed the top cover and took a small screwdriver and moved things around a little bit.Then I hooked it back up and started working again.I'd try that before taking the faceplate off.I bought the tool to remove it from the dash at Walmart for around $5,it only took a few minutes to remove it from the dash and take the 2 screws to take top cover off.
Old Apr 1, 2009 | 04:35 PM
Robs06SuperDuty's Avatar
Robs06SuperDuty
I went thru 2 Stock CD Players, both did the same damn thing. Both were covered under warranty but after the 2nd one I said f it and put a headunit in, along with door speakers amp and subs. No more Problems.
Old Apr 2, 2009 | 10:04 AM
darthracer777
Special tool for it? Was it a micro-screwdriver kit? Exactly what tool did you use so I can get the right one.
Old Apr 2, 2009 | 03:47 PM
mnpowerstroke99duty
The tool was for removing the stereo from the dash.I just used a small flat screwdriver to move things around inside.
Old Apr 3, 2009 | 12:19 AM
built tough's Avatar
built tough
Ford stock stereos suck
