390--428????
Old Apr 1, 2009 | 12:05 AM
sssilvernblack's Avatar
sssilvernblack
390--428????
Hi all........I recently puchased what I was told was rebuilt 390 from a 68 f100. needless to say it has some issues and yes i'm going though the bad areas. my question is the block casting is C7ME-A (428?)and the crank is a 2-U (390?) and it looks to be 4.13 bore with D2TEAA heads with smog holes ?. any info would be greatly appreciated.............Thanks
Old Apr 1, 2009 | 02:18 PM
JesusRocks's Avatar
JesusRocks
well the book says 428 block, but with 390 stroke that gives you a 405. Rebuilt seems to be a little of an understatement haha. How does it run? any problems or just curious as to what you have? oh and I'm guessing it's internally balanced but check the flywheel for a counterweight anyway, I mean it wouldn't be the first thing to surprise you right.
Old Apr 1, 2009 | 02:51 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
4.13 is a 428 bore, and the 2U crank is 390 stroke, so you are correct.
Interesting find.
D2TE-AA heads are the 1972-up truck heads, same as the 1968 C8AE-H castings with hardened exhaust seats (which aren't, after a valve job).
Check the exhaust (and intake) valve diameter, maybe someone put CJ valves in them.
Old Apr 1, 2009 | 03:00 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Measure carefully. A .060 390 will show a 4.11 overbore. Look at the pistons they should have a size stamped/cast into them or at least a part number depending on the make. That should be a clue. The block can be a 390 or 428 with the C7ME-A. Not that the casting number makes a difference. You can look at the back of the block and look for the A or C sandscratch. That would sway things towards a 428 block. If it is a 4.13 bore and 3.78 stroke it's a 406(+) displacement depending on exact bore size. And the pistons would be sought after ($$$) if so. They are hard to come by. If original Ford 406 piston they'd be a TRW forged flat top. See what you can find.
Old Apr 1, 2009 | 03:02 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
BTW Art you might as well change that "YOTA" avitar to a bowtie. Sheesh.
Old Apr 1, 2009 | 03:23 PM
krewat's Avatar
krewat
April Fool's
I thought about a bowtie, but figured 'yota would be scarier
Old Apr 1, 2009 | 03:38 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Originally Posted by Krewat
April Fool's
Sure is fugly.
Old Apr 1, 2009 | 03:51 PM
Bear 45/70's Avatar
Bear 45/70
I was under the impression that Ford called a 4.13" bore block with a 3.78" crank a 406 and produced that engine for several years prior to the 427. FFR428 is right, check the pistons as a .060" over 390 block is 4.11" which is real close to 4.13" with wear.
My April Fools joke was it snowed. Globle Warming my cold butt!
Old Apr 1, 2009 | 05:31 PM
JesusRocks's Avatar
JesusRocks
yeah you're right Bear, haha I got back on here, and re-read th post and was kinda dumbfounded. I thought well isnt that just a 406...and it is. Rough day, long night last night, still a little slow.
Old Apr 1, 2009 | 05:32 PM
JesusRocks's Avatar
JesusRocks
Sure is fugly.
Agreed
Old Apr 1, 2009 | 05:44 PM
krewat's Avatar
krewat
Try to join it and keep it nice, but look here:
https://www.ford-trucks.com/forums/8...nt-toyota.html
If anyone can put up some posts saying "I talked with Art and he's sorry to have done it" or something to that effect
Old Apr 2, 2009 | 08:53 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Oh Art I left a good one for ya!! LOL
~RJ
Old Apr 2, 2009 | 10:30 AM
krewat's Avatar
krewat
Thanks Russ, I already said last night that it was an April Fool's Joke
Old Apr 2, 2009 | 12:53 PM
RapidRuss's Avatar
RapidRuss
LOL, Art !! I just couldnt resist....after all that was a cold trick on US too !! Hey look at the bright side at least I kept your wife in a German Sports car!!
Old Apr 2, 2009 | 03:39 PM
krewat's Avatar
krewat
Thanks Russ
I'd rather a British sports car, but hey, beggars can't be choosers
