Tach Pickup
Old Mar 31, 2009 | 11:12 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Tach Pickup
Hi all,
Ok, I asked this Q on the 80-86 forum (https://www.ford-trucks.com/forums/8...connector.html) and have yet to get a response, this is the more appropriate forum any hoo! (Thanks to their help I've found the Tach leads)
I'm working towards a tach install on my 86. (Any one got one they want to sell)
On the 6.9L the tach sensor is located in the IP drive housing. (Proper Name??)
  1. What is on the IP drive gear that the pickup senses?
  2. Would it always be there? (Even in Tachless versions)
Thanks Y'All for doing what ya do!
-Enjoy
fh : )_~
Old Mar 31, 2009 | 11:24 PM
LCAM-01XA's Avatar
LCAM-01XA
1. It sees the gear teeth, all of them.
2. Gear teeth are always there, obviously Sensor will not be there in a tach-less truck, but the gear housing may still have the provision for it, with a plug closing it off. I say may, cause many tach-less trucks had a smooth gear housing. There are actually three gear housings - an entirely smooth one with no oil fill neck and no sender provision, one with sender provision but still no oil fill neck, and one with both sender provision and oil fill neck.
Old Mar 31, 2009 | 11:27 PM
starmilt's Avatar
starmilt
If your gear cover has the provision for a tach there will be a plug in the top that takes about a 1" wrench. if the plug is not there you need a different gear cover and the tach sensor that goes in the hole that is plugged. I'm not sure if the wiring is in place or not.
Old Mar 31, 2009 | 11:46 PM
Festus Hagen
Methanoholic
The gear teeth is exactly what I wanted to hear.
Yes, The wiring is in place, Yes I have a plugged Pickup port in the gear housing.
I guess I'm all set, Just need to find (and buy) a Tach and pickup.
Thanks y'all.
-Enjoy
fh : )_~
Old Apr 1, 2009 | 12:13 AM
starmilt's Avatar
starmilt
Usually the sensors are allright if the insulation on the two wires is in good shape and guys here have bought them at wrecking yards for next to nothing. That probably depends on your location though as the wrecking yards here with no competition think their stuff is better than new.
Old Apr 1, 2009 | 01:19 AM
LCAM-01XA's Avatar
LCAM-01XA
Lol, no way I'm buying something so small from the U-Pull-It - I got deep pockets, thankyouverymuch
Old Apr 1, 2009 | 09:59 AM
Festus Hagen
Methanoholic
I would not buy a used sensor/pickup unless they are hundreds of dollars, then I just might THINK about it!
The Sensor/Pickup is not the issue, The Tach is... It appears they are hard to come by used.
-Enjoy
fh : )_~
Aune163rd
Dec 13, 2014 08:02 AM
Aune163rd
Oct 11, 2011 01:49 AM
Old Hickory
Feb 26, 2011 08:39 AM
hugger94
Apr 18, 2008 09:56 PM
pjckm
Oct 15, 2007 10:28 PM
