Welding hook up help..
Old Mar 31, 2009 | 09:27 PM
Fordmclovin's Avatar
Fordmclovin
Hey guys,
I am stuck. Just got a new place with no hook up for my welder.
Just need some thoughts.
If I put a normal house hold plug onto the welder and ran it off a normal plug it will trip the breaker. What if I put a bigger breaker in like a 50amp?
Will it still trip?
Any ideas would be great...
Cheers
Chris
Old Mar 31, 2009 | 09:31 PM
Jermafenser's Avatar
Jermafenser
This isn't the correct forum for this.
But whatever you're attempting, it sounds like a recipe for disaster.
Old Mar 31, 2009 | 09:32 PM
Holiver31's Avatar
Holiver31
depends on your wire gauge that goes to the breaker,,dont want to small with a big breaker,,youll burn up your wiring
Old Mar 31, 2009 | 09:39 PM
Fordmclovin
Sorry,
There were no forums that I saw that had welding? Maybe i over looked it but because I drove a 77 f250 thought to slap it in here. Sorry if i put this in wrong forum.
But just wondering if this would work? 50amp breaker and plug the welder with new male end into a normal plug?
Old Mar 31, 2009 | 09:51 PM
zenmaster's Avatar
zenmaster
Fordmclovin,
There is a "welder question" thread in the 61-66 forum right now. You might find help there as well.
Good luck!
Old Mar 31, 2009 | 10:06 PM
Bgasrickshaw's Avatar
Bgasrickshaw
Unless this is a 110 volt welder you should not be trying to run it on 110 volts.( if that's what you are doing, - sounds like it-) You need to find out what the required power is for your welder and wire accordingly to suit it.
Old Mar 31, 2009 | 10:20 PM
laynejc's Avatar
laynejc
your best bet would be to hire an electrician, unless all new wiring has to be ran it shouldnt be very high, plus you could save yourself a headache and maybe even worse
Old Apr 1, 2009 | 12:27 AM
Fordmclovin
Awesome thanks guys,
Its a 220 miller thunderbolt. I will have to get one up here to wire in a new spot.
Cheers
Old Apr 1, 2009 | 12:36 AM
kshaneh's Avatar
kshaneh
electrician for 8 years, umm you will have to run a new wire, if you put a 50A breaker on the wire you will fry everything and possible burn ur house down.. just better to run a new wire man
Old Apr 1, 2009 | 01:38 AM
flamebuster's Avatar
flamebuster
kshanen said it all . good post......
Old Apr 1, 2009 | 03:54 AM
kshaneh's Avatar
kshaneh
thanks ne question feel free to ask, have wired about 3500-4000 houses in ohio, a college, strip mall just to name a few...
Old Apr 1, 2009 | 10:25 AM
ChaseTruck754's Avatar
ChaseTruck754
Is everybody assuming he has a GAS dryer - instead of an ELECTRIC one in the garage?
If he has an electric it is probably 220v and I would be wired with 12 ga solid (not strand) wire - depending on the age of the house.
I would do a little investigating to see what it is (shut off breaker and pull socket out of wall - look at wire type/gauge) and then make the cecision from there...
Old Apr 1, 2009 | 12:29 PM
Fordmclovin
I dont know anything about wiring a house thats why I am asking. I will just hire someone to do it. How long of a job do you think it is to put a new line in and what not? 1 hour or couple hours?
Cheers
Old Apr 1, 2009 | 01:00 PM
Alvin in AZ's Avatar
Alvin in AZ
"how long its a piece of string?" -Mr. Case (my 6th grade teacher)
Alvin in AZ
Old Apr 1, 2009 | 01:03 PM
ChaseTruck754
Alvin in AZ
Huh?
Cheers
Too hard to tell over the internet. Ask the guy when he shows up to look at doing the job - hahaha
