View Poll Results: What does your speedometer go up to?
85 MPH
37.50%
100 MPH
57.50%
130 MPH
2.50%
I don't know, mine doesn't work!
2.50%
Multiple Choice Poll. Voters: 40. You may not vote on this poll
Speedometer
Old Mar 31, 2009 | 04:32 PM
Tees77f150's Avatar
Tees77f150
Speedometer
I am sure there is an obvious answer, but I am going to ask anyhow. I noticed my 77 has a speeometer that goes to 85 mph.
Then I see others that go to 100mph. Then I have seen a few that went to if I remember correctly 130.
I am thinking the year it was made, and or the package it came with.
Old Mar 31, 2009 | 06:27 PM
Jermafenser's Avatar
Jermafenser
There are NO speedos that went 85MPH in 1973/79. It's either 100, 80, or 130.
1973/76 clusters were all black with red needles that went 0-100MPH and has no km/h conversion. No fasten belt light. Only BRAKE (left side) and HI BEAM (right side) NOTE: In 1975 only, "LOW FUEL ECONOMY" light was installed on the right side of the cluster.
1977 is the only year that still has an all black cluster, speedo went to 80mph with the km/h conversion. 1977/79 needles was changed from red to orange. There's some speculation that early 1977 vehicles still had the 100mph speedo. Added FASTEN BELTS light on the left side; HI BEAM went to a tiny rectangular blue lamp above the speedo. BRAKE went on the right side. Added 'NORMAL' under the range on gauges.
1978/early 79 have argent walls with black faces. Needles were still orange, and the speedo went 80mph with the km/h conversion.
Mid to end run 1979 (1/79 onwards I'm guessing) had argent walls and faces. Only the gauges themselves were black. Same orange needles and 80mph with the km/h conversion.
The 130 number is only for Canadian trucks. It is measured in km/h instead of MPH. It also has the MPH conversion. Added in 1977.
Old Mar 31, 2009 | 06:38 PM
zak8tac's Avatar
zak8tac
The cluster I pulled out of my 76 was all black 100mph like it says above, however it did have the spot for the fasten seat belts light, it just wasn't operable...I put in a 78 ranger cluster which is 85 mph and grey instead of black, and might I add the lights are wayyyy better at night, I can see every gauge now instead of almost seeing one or two haha. Now that I read jermafenser's post a couple more times my original (original to me, who knows if it was original) was the cluster described for the 77/79. Either way I prefer the grey ranger gauges and the 85 mph limit, looks like I'm hawlin butt cuz the needle is ready to fall off at 70 haha. BTW the ranger gauge also had km/hr.
And BTW it goes to 80 mph in numbers, and has the line for 85 mph. Pics are in my gallery
Old Mar 31, 2009 | 07:18 PM
Jermafenser
I looked at the pics...both clusters seem correct, original and what you replaced it with. On the original, I don't see the fasten belt lights on the left? It looks blank to me. Was it blacked out or something?
Old Mar 31, 2009 | 07:56 PM
Damstr8's Avatar
Damstr8
Yeah I am the one so far with the 130KM. Long story, but it had everything my grandpa wanted and they brought it down from Canada.
Old Mar 31, 2009 | 08:02 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
1976 clusters definatly had the Fasten Belt lamp. It was also the first year Shoulder belts were standard equipment.
As for the changing of the 100MPH speedo, to the 85MPH speedo, this is due mostly to the 1973 oil embargo. They lowered the speed limit to 55MPH, and lowered the speedometer reading because 30 over the speed limit is reckless driving in most states, and you tend to drive slower if you don't know how fast you are going. Thus saving gasoline and oil.
Old Apr 1, 2009 | 12:20 AM
bulletsneverlie's Avatar
bulletsneverlie
I got 100. I do know these clusters are some of the ugliest I've ever seen. It looks like three old square cheapo wind-up alarm clocks. I'm about to be swapping in a round 5 inch Oldsmobile speedo with 120mph on it from a '66 Dynamic 88. The Revs Per Mile is 748, so it's close. I do have to use the speedo cable from a '69 F100, but it works. I think I'm gonna eventually swap the whole dash.
Old Apr 1, 2009 | 12:39 AM
unrulee's Avatar
unrulee
Mine in my 79 goes to 100, because I swapped from the original 80 mph'er.
kshaneh's Avatar
kshaneh
well mine goes to 80, and i got a 100mph sittin around
Old Apr 1, 2009 | 01:39 AM
Dirt racer's Avatar
Dirt racer
I am not sure what mine was originally. My 75 F100 4x4. But it had the fuel economy light. I had an engine fire and it toasted my instrument panel. Got one from the local u-pull for like $10 and put it in. Didn't even notice it was a 100mph one till about 6 months ago. Cool find though. I have a 79 parts truck with the silver sides. Think I might put that on it. I think its 80 mph on the speedo part.
Old Apr 1, 2009 | 07:43 AM
unrulee's Avatar
unrulee
Originally Posted by Dirt racer
My 75 Silverado 4x4.
Huh?
Old Apr 1, 2009 | 08:16 AM
bulletsneverlie
April Fools! Every one is big on it around here, so I slept with one eye open, and I'll be watchin' my back all day!
Old Apr 1, 2009 | 06:19 PM
zak8tac's Avatar
zak8tac
The cutouts and lens and bulb for the lights are there they just dont light up.
As far as 76 being the first year for standard shoulder belts nope...Don't know what year it was but it wasn't 76 cuz mine is definitely original cab and I only have lap belts.
Old Apr 1, 2009 | 09:21 PM
81-F-150-Explorer
It was the 1976 year model.
I know this because they were standard on my father's 1976 F-100, and he wanted a 1976 truck without them, and was told he couldn't get one.
The only thing I can think of why the discrepency, (because you are not the first one to say this) is either it was California only, OR it was introduced mid year.
Shoulder belts were optional as far back as 1968 on the F-series.
Old Apr 1, 2009 | 09:26 PM
zak8tac's Avatar
zak8tac
That might be possible or maybe the GVWR of the truck as mine is an f-250... My truck was also built at the end of 1975... I dunno, be NumberDummy could sort that out though! lol
