Cross over for Ford part number
Summit Racing does not know what they are doing. They recommended the wrong power valve - a single stage - that would have damaged my engine.
I called Holley and sent them photos. The only way to get the power valve for a E6JL-9510-AB carb, (which is a Holley number LIST 50278-1 1826) is with the complete Holley 3-1346 rebuild kit.
Also, the backfire preventer kit will work with this. The instructions are vague. The check valve is installed in the carb base in the smaller hole that lines up with the little brass insert in the upper body that leads to the niche that the power valve lives in.
Interesting claim by this "Holley expert" but even my stock 428CJ pulled less than 2" of vacuum at WOT.
Holley recommends 1/2 of idle vacuum. -shrug-
I surmise that is for performance where the engine is either WFO or closed throttle.
My truck pulls over 23", should I be using one that opens at 12???
This is the reason for 2 stage valves.
https://www.ford-trucks.com/forums/1...l#post10493176
Post #31, 6/23/11
Post #31, 6/23/11
....A single stage valve is +/- $15 as opposed to $30 or so for a two stage.
You can use a single stage PowerValve if you like, try something around 6.5"hg.
You will lose a little economy and the transition will be more abrupt.
There is a wide selection of PowerValves (24 actually) on Holley's Amazon store
Sam's1967
22
02-11-2023 04:56 AM
joegeds
11-02-2016 10:44 PM
wreckinball
03-08-2011 08:56 AM
60RatRod
06-13-2010 09:07 PM
