Parts Cross Reference or Interchangeability Catalog
Old Sep 2, 2015 | 06:01 AM
Sam's1967's Avatar
Sam's1967
Sorry if this is the wrong Forum for this question!
Anyone know of a Ford book/catalog or CD that identifies parts interchangeability from the engineering numbers, the actual part numbers and the vehicles (yrs, makes and models) that the part may fit?
Old Sep 2, 2015 | 06:55 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1) O-S-I (Obsolete-Supercede-Interchange) Catalogs cross old Ford part numbers to new Ford part numbers.
The problem is, none are reproduced on C/D's and there are dozens of different bound paper editions!
Ford combined dozens of these bound paper O-S-I catalogs, put them on microfiche. The 1991 microfiche O-S-I catalog has parts listed from the 1940's thru 1990.
I have this catalog, also a microfiche viewer.
2) Ford Master Cross Reference Catalogs cross ID Engineering numbers to Ford part numbers. Again, there are dozens of bound paper editions, none are reproduced on C/D's.
I have dozens of these bound paper catalogs from 1960 thru 2001.
Old Sep 2, 2015 | 09:54 AM
Sam's1967's Avatar
Sam's1967
What catalogs would you recommend that cover 1967 through 1979? Do you know of any that may be available?
Old Sep 2, 2015 | 10:02 AM
NumberDummy
faxonautolit.com (store located in Riverside CA) has O-S-I catalogs, but which ones to buy?
Ford came out with at least two editions per year, the same info isn't in either, so you would need dozens of O-S-I bound catalogs that cover from 1967 thru...at minimum 1990.
IMO, the only way to be absolutely sure you have all the 1967/79 info is to get a 1990 or 1991 O-S-I catalog on microfiche (2 slides per year), then you'll need an ULTRA VII viewer.
In the late 1980's, FoMoCo changed the package quantity of a gazillion parts. When the IDIOTS did this, they changed the part numbers suffix, rendering all the original part numbers obsolete.
And, FoMoCo is in-famous for replacing/updating 10's of 1000's of part numbers EVERY YEAR!
Where in CA are you?
Old Sep 2, 2015 | 10:12 AM
Alex from GA's Avatar
Alex from GA
IMO your best bet would be to post your needs on this site and Bill(NumberDummy) can give you the most recent part numbers.
Old Sep 2, 2015 | 10:13 AM
NumberDummy
FTE member JEFFFAFA also has this info, as he's a parts guy at an AZ Ford dealer.
Old Sep 2, 2015 | 03:12 PM
JEFFFAFA's Avatar
JEFFFAFA
Are you trying to find out what will fit where on your rig or gather info to EBAY a bunch of stuff?
Old Sep 2, 2015 | 03:13 PM
JEFFFAFA's Avatar
JEFFFAFA
Yepper, I am.
Old Jul 5, 2017 | 02:09 PM
jimstack's Avatar
jimstack
Good Day:
Request for NumberDummy - I'd like to replace my original 1976 starter motor, FORD part # C6FF-11001-B and wondering if you could kindly provide today's equivalent/modern FORD/Motorcraft part number?
Greatly appreciated, Jim
Old Jul 5, 2017 | 02:55 PM
JEFFFAFA's Avatar
JEFFFAFA
Originally Posted by jimstack
Good Day:
That number doesn't show up in my slides anywhere. Are you sure it's "C6FF". What is this starter on? Some kind of Industrial equipment, Irrigation, or Marine application?
"C"= 60's decade.
6= the year in the decade. 1966.
"F" = Ford used for the Pinto.
There were no Pintos in 1966. I have seen the 3rd digit of "F" in some Industrial applications. Ford Power Products division. Not Ford Parts and Service division.
Old Jul 5, 2017 | 05:58 PM
jimstack's Avatar
jimstack
starter
Thanks for the quick reply. The starter was used in 1976 on AMC's JEEP CJ-5, 258ci 6cyl 3spd base model. AMC's part # is 321 2235 and I also have FORD # D0FF-11001-B and D6FF-11001-AA and -BA coming up on my Internet searches. My AMC Parts Book states it is a MOTOCRAFT starter 321 2235.
Again, I'm grateful for any info you can provide. Jim
Old Jul 5, 2017 | 07:36 PM
NumberDummy
Request for NumberDummy - I'd like to replace my original 1976 starter motor, FORD ID engineering # C6FF-11001-B and wondering if you could kindly provide today's equivalent/modern FORD/Motorcraft part number?
C6 would be 1966, but there's no FoMoCo truck or car ID number prefix of C6FF
What size is the engine, A/T or M/T?
1966 FoMoCo starter ID number prefix could be: C6AF; C6OF; C6TA or C6VF
You should list the vehicles you own in your signature, as your "About Me" profile says 2017 F150.
Notice my signature says 2017 Fusion (as of 7-5-17).
Old Jul 5, 2017 | 07:50 PM
KULTULZ's Avatar
KULTULZ
Post
I think the third prefix character F is for OUTSIDE SALES, which would make sense as he is mentioning AMC.
The 4th character F is ELECTRONICS DIV which then may have been ELECTRICAL. E is for ENGINE, not electrical.
These are Engineering Nos. and of course I don't have to tell you that.
This is not confirmed and I have been wrong in the past. I think that's how I winded up married...
Old Jul 5, 2017 | 07:52 PM
KULTULZ's Avatar
KULTULZ
Post
If you want to retain the original case, I would rebuild that one or have it rebuilt.
Old Jul 5, 2017 | 08:14 PM
NumberDummy
I thought that too.
The 1966 FoMoCo starter ID engineering numbers that include 11001 are: C6AF-11001-A - C6AF-11001-B - C6OF-11002-A - C6TA-11001-A & C6VF-11001-A
